Idle two low
Old Oct 16, 2005 | 10:46 PM
isissound's Avatar
Idle two low
All right in the past when my idle has dropped two low I jest tighten up the throttle linkage adjustment when I looked in my repair manual and read up on it you guys talk about a low idle adjustment screw but I cant find it can some one help me
Old Oct 16, 2005 | 11:09 PM
Cartman's Avatar
its kind of a pain to find...
with the engine off stick a screw driver in the linkage to pull the throttle wide open...feel around just to the left of the primer bulb....i just feel around for a piece of threaded rod. you will not be able to see it. It's easiest to reach under the brake master cylinder and equip yourself with a 10mm end wrench. You will find it, its just kind of hard to explain
Old Oct 17, 2005 | 08:11 AM
Dr. Evil's Avatar
Idle should be 800 rpm with truck in gear (or drive) with AC on.
Idle adjustment is a bit on the painful side. The first time will be the worst. The adjustment screw is on the back of the injector pump, you have to do this blind as you wont be able to see the screw. If you get under the truck and look up at the pump youll see it:
http://www.dodgeram.org/tech/dsl/adj...d_Gen-Idle.htm
Theres plenty of info here - just do a search:
https://www.dieseltruckresource.com/...dle+adjustment
outside304
Jun 12, 2010 06:14 PM
Totallyrad
May 23, 2010 12:42 PM
dieselcarpenter
Nov 17, 2007 07:02 PM
crobtex
Oct 15, 2006 09:59 PM
Dieseldude4x4
Jan 4, 2003 03:07 PM
