Idle Problem
Old Sep 12, 2004 | 11:18 AM
PIRO 710's Avatar
Question Idle Problem
Quick question for the wiser guys, my 97 is only two months old to me and I have adjusted the idle up two times already, wondering if there might be another problem I am not aware of. Thanks
Old Sep 12, 2004 | 12:10 PM
MnTom's Avatar
What kind of idle problems are you having? I wonder if you need to change the rubber fuel lines above the starter. They are a known problem because they rot and leak a little air. You could also have a slight air leak somewhere else too. Mine had a slight leak on the top of the fuel fliter.
Tom
Old Sep 12, 2004 | 12:44 PM
PIRO 710's Avatar
The problem is the idle with the a/c on goes down to bout 550 and if the truck is cold, it stalls out but as soon as I adjusted it had no more problems for about a month.
Old Sep 12, 2004 | 06:06 PM
Smokee's Avatar
PIRO 710, your throttle cable may be fraying, Check for a recall.
Old Sep 12, 2004 | 06:12 PM
PIRO 710's Avatar
Thanks guys will check that cable, it sounds like the problem.
Old Sep 12, 2004 | 08:33 PM
infidel's Avatar
There are two small bolts on the part (bell crank) opposite where the rod from the throttle cable connects that smetimes come loose or one will fall out, check for tightness.
Old Sep 13, 2004 | 09:07 AM
Rrloren's Avatar
Had same problem couple months ago. Turned out to be fuel overflow valve,cost $32, still needed to adjust up the idle tho. No problems since.
freds89
May 7, 2009 08:54 PM
pet05
Oct 5, 2006 11:02 AM
rdc
26
Jul 31, 2006 09:17 AM
dieselnewbie
Jan 18, 2005 10:48 PM
steelsoldiers
21
Dec 19, 2002 04:08 PM
