i think my grid heater isn't working
Old Dec 28, 2004 | 03:09 AM
halerazor's Avatar
whenever it is below 20 degrees it takes me about 5 tries to get my truck started. i turn the key and the wait to start light comes on and the volt meter ges down and comes back up i crank it and it fires then shuts off. i have to do this about 5 times before it finally starts idiling, but it misses and sputters real bad shaking the truck. my lights aren't dimming on and off so i think it's the grid heater or could it just be the oil i i'm using 15w-40 amsoil. if i leave it plugged in it fires right up so i don't think it has anything to do with any fuel problems. how can i test the grid would it be a good idea to pull the air intake horn off and see if it glows red when i turn the key.
Old Dec 28, 2004 | 03:47 AM
dalton4's Avatar
A low idle will require a small amount of throttle input during cold starts. Cold starts within themself can require some throttle until the engine levels out.
If your voltage gauge is cyling back and forth that would be a general indication that the grid is working. Ohm reading on threaded cable terminal of heater to ground should be"0" if checking the heating grids.
Old Dec 28, 2004 | 03:55 AM
halerazor's Avatar
if i add throttle the truck stalls and shuts off
Old Dec 28, 2004 | 10:36 AM
durasmack's Avatar
do you hold the throttle open slightly (keep the rpms around 1000) for about 15-20 seconds after it starts? mine will stall if i let off the throttle imediately after it cranks.....
Old Dec 28, 2004 | 11:52 PM
farmer dave's Avatar
I had similar problems with a 97. The truck would start real hard if not plugged in, but if I plugged it in it would start fine. The flucuation on the voltage doesn't tell you much, mine flucuated yet wasn't working. My problem was a bad solinoid relay to the grid heater. Not very expensive to fix. You can check the voltage readings around the solinoids.
Old Dec 29, 2004 | 04:50 AM
halerazor's Avatar
i found it the terminal for the relays that connects to the battery was corroded in half
Old Dec 29, 2004 | 09:00 AM
durasmack's Avatar
that'll do it every time....
redneck2thamax
Feb 19, 2008 04:10 AM
Red3quarter
Dec 22, 2006 10:19 PM
A-Poc
May 5, 2005 09:52 PM
greasy
Mar 14, 2005 12:35 PM
Dodgezilla
Mar 13, 2003 06:14 AM
