Heater blower isn't working
Old Feb 13, 2008 | 03:42 PM
redneck2thamax's Avatar
just the other day i tried to turn on my heater and it wasn't working. i turn on the defroster and the vent and neither one worked. i checked the fuse and its fine but it still doesn't work. what could it be?
thanks
____________
1989 d250 2wd diesel single cab long bed.
Old Feb 13, 2008 | 04:38 PM
leper's Avatar
Turn the setting to high, go out under the hod and check voltage at the connector. Or just smack it on the backside while you are ther to check voltage.
Old Feb 14, 2008 | 01:16 AM
ofcmarc's Avatar
If you have no fan speeds, it is typically the switch if the fuse is good. Low speed only would be a fan motor going out and high speed only a resistor. But not always. The circut is fairly simple to follow. Start at the motor and work backwards towards the switch and you'll find the problem.
Old Feb 14, 2008 | 06:29 AM
91rangerturbo's Avatar
I had mine quit about a month ago on me. Double check your fuses. Mine was loose in the fuse panel and was causing a bad connection.
Old Feb 14, 2008 | 04:50 PM
well im going to try to fix it all this wknd hopefully so we'll find out soon.
Old Feb 18, 2008 | 06:19 PM
i got my heater blower working. all it was was the controls. they went out for some reason so i took one outta my other truck and put it in an it works again. thanks for the help
Old Feb 19, 2008 | 04:10 AM
Jim Lane's Avatar
Post
This is usually what will lead up to your blower motor first becoming intermittent and then failing all together.
This will usually start to smell at first and then there may be some smoke.
This was a genuine BUSS fuse.
At this time you also need to put your hand carefully on the bottom of the steering column below the ignition switch and see if it is hot, about the same time the wiring and ignition switch had burned up.
You might notice that when you turn the key to ON or Start that it will stick.
There is too much resistance in the wiring and in all of the connections for the blower motor.
There is a schematic for the blower circuit in here. https://www.dieseltruckresource.com/...d.php?t=158400
Jim
Red3quarter
Dec 22, 2006 10:19 PM
A-Poc
May 5, 2005 09:52 PM
greasy
Mar 14, 2005 12:35 PM
halerazor
Dec 29, 2004 09:00 AM
Dodgezilla
Mar 13, 2003 06:14 AM
