I have a Ford but just bought a Dodge ...?
Hi Guys
I could not pass on a Dodge I just seen , It's a 96 with 150,000 on the motor ... I could not pass on this truck ...SOOO clean , the motor's original paint was perfect , you could tell very well maintianed .
It has a full amsoil system on the passengers side ...Two filters I know nothing about those systems ...a little help with that .
On the drivers side theres a what looks like a heat shield shaped like a triangle with another filter under that ...a little help with that too...Please...
The feels very strong , it has a what looks like 3 1/2 exhaust with a flow master , also the trans feels like it has a shift kit and it also has a mag-hy-tec deep sump pan ...very good .
I could not beat the guy up that bad ... very nice truck and had to be well kept in that condition , no blow by and no leaks ... I have a great feeling about this truck ... un like my ford .
The only thing ... they put new crappy tires and no front end alinement ...pulled a little to the right , I'll check all that out ball joints and bushing ... everything felt good , I used there floor jack and gave it the once over ... you never know used ... I felt I could not go wrong .
I gave him 9 grand out the door ... not to bad in this shape .
Later guys
Greg
Later guys
Greg
sounds like a "Prime Lok". It is a remote fuel filter. The stock location sucks and is a cartridge instead of a spin-on.
Randy
The Amsoil system is a dual bypass filter system. It has a full flow filter that is changed occasionally and top off the oil, then once a year you change both filters and the oil, or more often depending on how many miles you drive. If you check Amsoil's website, it gives oil service interval recommendations, all of this assumes using the Amsoil synthetic oil. I had one on my DMAX, but I don't drive enough miles for it to be cost effective, so on my Dodge I just use dino oil & regular filters. Of course you could use the bypass filters with regular oil also. The bypass filter filters out smaller particles than a regular filter. Hope this helps!
If you have the time, you might get under the truck, and pull off the inspection plate for the torque converter, and see what color the torque converter is, and spin it around and see if it has a drain plug in it anywhere. May have an aftermarket TC!
Eric
Eric
Just Drop this truck at its new home ...
I just got it home ... I am very happy with this truck , I love the sound of the cummins engine and with the 4" exhaust ... even better .
It is not a perfect truck being 10yrs old , even with 150,000 on the truck it's a great truck .
Thanks guys
Greg
Thanks guys
Greg
Flowmaster
I know flowmaster dose make a muffler for the diesel , but it looks like it's been on here for some time ...
Just before the flowmaster there is a wear cone shaped can ... I'm not sure if it's a cat or some kind of resinator ... ?
Greg
Greg
Big James
Introductions / New People
Jan 26, 2010 09:09 PM
dizzel
Jun 27, 2009 05:19 PM
mattyfz450
Feb 22, 2009 08:12 PM
Scott03HO
Dec 2, 2004 03:59 PM
bighogleg dodge
Aug 21, 2004 02:32 AM
