hey all need help asap
Old May 5, 2008 | 07:31 PM
staken's Avatar
hey i need a rear whiel seal for a 95 and they askt what it has for a rearend a dana 60 or dana 80 if eney one knows let me know asap thanks staken
Old May 5, 2008 | 07:41 PM
kelownadiesel's Avatar
what is the truck a one ton or 3/4 and is it auto or manual?.If its a manual is is likley an 80 and if its an auto it is a 70 most likely
Old May 5, 2008 | 08:51 PM
staken's Avatar
its a 2500 3/4 and its a manual
Old May 5, 2008 | 09:22 PM
lobes1985's Avatar
its most likley a dana 80, you could also check the tag that located under the hood
Old May 5, 2008 | 10:47 PM
Lil Dog's Avatar
Looks like its an 80 by the listing on Dodge Ram.org . It has all the info for the model years in the specifications area.
Old May 6, 2008 | 09:17 AM
infidel's Avatar
It's an 80 but most autoparts need more info or they'll give you the wrong seal.
After giving me the wrong one my Napa guys had me bring in the brake drum.
They took a couple of measurements on the drum and viola, had the right seal.
Old May 6, 2008 | 09:27 AM
Captain's Avatar
it should be a dana 80. Also on the rear diff. Look at the cover bolts. Between 2 of the bolts should be a tag telling you the rear and what gears and all are in it. And as someone else said under the hood is a tag with your truck's options.
Old May 6, 2008 | 10:07 AM
12 flapper's Avatar
If you look at the front of the rear around the pinion the is 80 stamped on each side in the cast if it is an 80 I don;t think I have seen a stick truck with a 70?
Old May 6, 2008 | 05:13 PM
shorthair's Avatar
I quit doing napa after they tried to sell the wife nuts for lag bolts.
5.9diesel
Apr 21, 2010 08:17 AM
horselady
Jan 27, 2009 12:01 AM
prairie pirate
Introductions / New People
Jan 18, 2009 10:26 AM
stock03
Sep 30, 2008 09:03 PM
staken
May 5, 2008 10:36 PM
