Help! Washer fell inside AFC housing
Old Sep 2, 2009 | 09:56 PM
97dodgeram2500's Avatar
So I took the plate out bout a year ago and I finaally made it a 0 plate and I went to put it in today and I dropped one of the washers into the housing and was unable to see or find it what should I do? Is it ok to leave in there or what will it mess up?
Old Sep 2, 2009 | 10:28 PM
G1625S's Avatar
Gotta come out, I would say. Try a magnet yet? Might have better luck pulling the plug on the side of the pump and fishing around with a magnet in there. You can slowly bar the engine over untill there's room through that hole to have a look. Good luck.
Old Sep 3, 2009 | 10:04 AM
infidel's Avatar
Starting the engine will cause severe damage, it has to come out.
Do whatever it takes to get it out even if it means removing the pump and shaking it.
Old Sep 3, 2009 | 01:41 PM
yes i did try a magnet and the motor has not been started since, what plug are you talking about removing and where would it be located? thanks
Old Sep 3, 2009 | 04:03 PM
Tate's Avatar
Pull the plug that holds the timing pin in. About a litre of oil will come out. Then take the back plate off the pump (the one to adjust the gov. arm) and fish through there with a small telescopic magnet. Once you get all the oil out, you can atleast see a little bit as to where you are fishing. The case itself is non-magnetic, but there are magnetic components inside the pump, so keep your magned down low.
Old Sep 3, 2009 | 06:55 PM
infidel's Avatar
The instructions here show going in though the plug> http://pacbrake.com/PDF/L5658.PDF
Old Sep 4, 2009 | 02:32 AM
catnfool's Avatar
thanks for the details, infidel; a good pic is worth a thousand words!!
Old Sep 4, 2009 | 11:15 AM
dieselman2300's Avatar
Take a turkey baster or a cheap transfer pump and suck the oil out throught the afc hole.
You need to get pen magnet that is flexible. It will come out.
Old Sep 5, 2009 | 02:26 PM
well guys i finally got the washer out thanks for all the help
Old Sep 5, 2009 | 02:34 PM
CamperAndy's Avatar
Tell us how you did it.
Old Oct 18, 2009 | 01:25 AM
Dave88LX's Avatar
Absolutely 100% needs to come out. Ask me how I know. Glad you got it!
beesting647
Dec 1, 2013 05:38 PM
DodgeDiesel61
Feb 23, 2013 05:17 PM
14racing
Feb 10, 2010 02:42 PM
kas83
Apr 16, 2009 12:23 PM
96_12V
Aug 7, 2008 04:45 PM
