Fuel Inside The AFC???
Old Feb 6, 2010 | 09:14 AM
14racing's Avatar
I pulled out my fuel pin today and there was fuel sitting down around the fuel pin. The other times i've pulled it out it has always been dry. It's not running out the little vent hose yet. Can someone tell me whats wrong? Is there a little seal around the little pin that rides on the fuel pin?
Old Feb 6, 2010 | 09:32 AM
Alec's Avatar
There is an o-ring in the bore around the "guide pin" that seals it. Personally, I would just keep an eye on things before going crazy trying to replace it. You have to take the manual shut off lever inside the pump cover out to replace that o-ring, IIRC.
Old Feb 6, 2010 | 09:36 AM
93flatbed's Avatar
Don't forget to check the sticky!
https://www.dieseltruckresource.com/....html?t=153154
Old Feb 6, 2010 | 11:13 AM
14racing's Avatar
Maybe it will stop leaking with summer fuel
Old Feb 6, 2010 | 12:05 PM
cougar's Avatar
No, it will only get worse. Oil is thicker when cold and thiner when hot. Adding a leak plugger (thickener) like WVO or WMO might do the trick,,,,or not?
Old Feb 6, 2010 | 02:49 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
The manual shut down lever doesn't need to be pulled to replace the oring.
The cause of the leak is the DennyT letting the guide pin travel too far.
I just resealed a pump top on my tuck 3 months ago and it is leaking again already
Old Feb 6, 2010 | 03:38 PM
cell's Avatar
Try backing out the starwheel a few turns.
Old Feb 6, 2010 | 05:35 PM
Firstgenfanatic's Avatar
I am experiencing the same situation. I am running an M&H "M5" fuel pin. I discovered that putting the stock pin back in eliminates the fuel leak coming out of my pump vent. I now have a little "over-flow" jar to catch the leaking fuel. Perhaps other folks are having similiar results with their performance pins.
Old Feb 6, 2010 | 06:00 PM
Rick 12v CTD's Avatar
yeah mine has leaked since I put my dennyt pin in a year ago but only recently has the diesel found its way out the little breather. I just noticed it today actually. It's not much so I'm not worrying about it. It probably only leaks when the guide pin travels down on our dennyt/M&H pins. Once it rides up a bit from lower boost I doubt it leaks. At least for me, mine isn't a constant leak. It wasn't leaking when I was idling my truck earlier.
Old Feb 6, 2010 | 08:19 PM
My little "catch-bottle" fills up very slowly over a long trip. I noticed fuel only leaks when the truck is under hard exceleration. This leads me to believe its the extreme grind fuel pin. I have learned to just live with it and empty the "catch-bottle" back into the fuel tank every so often.
Old Feb 6, 2010 | 09:51 PM
Now if you lend your truck out you'll know how much they got on it because you can tell how much fuel is in your catch jar
Old Feb 6, 2010 | 10:20 PM
dzl_damon's Avatar
Like said.... bigger travel from upgraded the DennyT or the MH5 etc allow the pin to ride out longer than it ever has in its life. There might be a little rough spot or a groove from where it used to always stop. Now it forces past the O-ring. My dually is doing it after my DennyT. I'll reseal the upper half of the pump soon probably, but I kind of don't care also!!!
Old Feb 6, 2010 | 11:19 PM
14racing's Avatar
I was also noticing the denny t was groovin up a bit. I was a little disappointed to see that.
Old Feb 6, 2010 | 11:34 PM
mine was grooved pretty good a while back which is why my sig now says "modified" DennyT pin. I've done a little grinding on it to lessen the angle at the top of the slope. I also bowled the bottom a little for a little further travel lol
Old Feb 7, 2010 | 10:30 PM
Rickcher's Avatar
I'm getting ready to order Denny's pin and expected the leak but figured the o-ring would fix it. Does the leak come right back with a new o-ring because the pin is traveling too far? Can you replace the pin and o-ring and cure it? Or is the leak something you just have to learn to live with? On a side note, how does the Denny T compare with other mods like turning the pump up or a 366 spring? Thanks
