Help Please: How much vibration does your engine give off? Problem?
Old Jun 1, 2007 | 09:29 PM
Common's Avatar
Sometimes the engine will vibrate at idle like it has an aftermarket cam in a gasser...
Wonder if its the exhaust just vibrating or what?
How much vibration do you get when you put your hand on the intake horn?
Shakes the truck a little...
Old Jun 1, 2007 | 09:30 PM
97' CTD's Avatar
The POWER of the CUMMINS
Old Jun 1, 2007 | 10:43 PM
funcruise's Avatar
Could be ideling a little slow.....
Old Jun 1, 2007 | 10:59 PM
Box5's Avatar
Has it been the same since u owned the truck, or is it somthing new? All i can say is u'll never try to start a cummins while its running like I did my sisters honda civic when I drove it alittle while ago, lol. These things are loud especially with the hood open, and vibrate alot. Have u checked out the motor mounts it sits on? there huge.
Old Jun 1, 2007 | 11:31 PM
Muddin_dude06's Avatar
Your idle is probably a little on the low side, idealy is should be 750-800rpm's with the A/C on. I know mine after towing a HEAVY load with the A/C on will lose 100-150rpm's than before I towed at idle.
Old Jun 2, 2007 | 07:34 AM
plow's Avatar
See if your motor mounts are good and tight also.
Old Jun 2, 2007 | 07:50 AM
Common's Avatar
You really think the motor mounts could be loose?
I'll check 'em...
Old Jun 2, 2007 | 08:13 AM
Common's Avatar
And what are some tell tale signs if I can't find anything?
Kinda soon to bust a mount, eh?
It doesnt do it all of the time...
Old Jun 2, 2007 | 11:08 AM
Box5's Avatar
does the idle drop when it vibrates? or sputter at all?
Old Jun 2, 2007 | 11:39 AM
Common's Avatar
I watch for it and it doesn't...
Old Jun 3, 2007 | 11:59 AM
Common's Avatar
So yeah? Anyone else?
Old Jun 3, 2007 | 12:49 PM
realtreehunter's Avatar
mine does the same thing but its cause idle is a little low but i think it looks kinda cool sittin there shakin side to side
Old Jun 16, 2007 | 07:08 AM
catnfool's Avatar
check out your harmonic balancer; mine has the rubber all messed up and is "hopefully" going to wait for the new fluidampner to be bought before it shells out...
Old Jun 16, 2007 | 08:22 AM
bob95065's Avatar
Change your fuel filters. I changed mine and it idles smooth now.
Old Jun 16, 2007 | 09:39 AM
John Faughn's Avatar
A ruff idle , like mentioned about the idle should be 850rpm AC on in gear .
Then check the valves for adjustment , thats a comin ruff idle cause .
When looking for problems I always look at the maintenance issues 1st , many times this will solve an issue , and may help to find an issue , when looking to solve a problem never go around unknowns ,
The last is that you said that it was not all the time , is it ruff when in gear and or AC - low idle .
If all above are good , it sounds like a fuel issue , try 10-20% bio-diesel [ this does a number of things , cleans the system better than anything , thats why those that do carry extra fuel filters , if not available , try 2cycle oil , both will make the eng. run quieter & smother at idle ,
I have been noticing that it seems that since the ULSD , that the fuel must very , same driving , & my millage will very by 1 1/2 - 2 mpgs .
sallyman1
Mar 16, 2010 03:47 PM
VikingDiesel
17
Dec 30, 2006 09:19 AM
motrapper
Nov 2, 2006 03:32 PM
duddin10
17
Oct 7, 2006 10:00 AM
Jack Thorpe
Sep 6, 2003 11:40 PM
