Help! changing dana 70 to dana 80, driveshaft too long???
I"m changing my 2500 to a 3500. Didn't really think the 80 was that much bigger till the old was out and gone. I had been planning this for a while, and listed my 2500 axle for sale on craigslist, planning on not swapping them till the 70 sold. Also so a potential buyer could see it still attached to the truck and running, so proof it was good. I didn't think the 80 would be any longer from the input yoke to the centerline of the axle( Yes, I am a bonehead for not checking this earlier)Once I realized my springs were the same, I breathed a big sigh of relief.. Sooo, tonight after work, I get my new u bolts and get the axle bolted in, and now wondering if my driveshaft needs to be shortened a little. I could get a prybar and pop it in, but seems a tad tight. Anyone else done this swap and know if the driveshaft needs to be chopped?? Trying to find out asap so I can take it out, get it to the shop, chopped and back for this weekend......
If it's long, it's not by that much......
Put the slip yoke into the transfer case, push it in all the way, then pull it out an inch. Now measure from the center of the u-joint caps on each yoke, give that measurement to the driveshaft shop.
Don't mean to hi-jack but maybe some other guys will have this same question. My 2500 has a Dana 60 rear because it was a gasser. Will a 70 just bolt right in for replacement. Also will the 60 last long with the diesel torque? Thanks
You definitely need an inch to an inch and a half travel on the sip tube. A shop can shorten it in an hour or so. Cost minimal if you need no yokes or joints. I had a whole shaft made when i put in a gear vendors for 200 bucks. Yokes and all. Brapp, the 60 is on the light side for the deisel, depends on how you drive it though.
My measurement indicated it was about an inch and a quarter too long. Have a friend with
The same truck I'm trying to build and had him measure, wich backed up my conclusion. Took it to the shop on fridayto have it shortened and the guy doing the work had to be taken to the er with chest pain. Soooooo, no way I'll have it back on the road tomorrow, have to wait till monday. This has actually been pretty easy. Springs were the same, as is the drive shaft u joint size. Going to hook the brakes back up tomorrow, install the fenders and then wait for monday...
I sold my 70 to a guy that had a60, hadn't heard anything back from him that it wouldn't work, but I think that truck has the more narrow springs and maybe the smaller u joints.
95black2615
Oct 14, 2008 12:56 AM
jkravito
Oct 13, 2006 05:16 AM
04ctd
Feb 9, 2006 12:04 AM
cheff
Jan 23, 2006 09:44 AM
