How long is too long Goosenek
Old Apr 29, 2006 | 02:02 AM
csramsey640's Avatar
I am looking for right around a 40 ft goose neck flat car hauler type trailer. Is only having 2 axles gonna create some sway problems? I would say 3 will be better, just wondering where to draw the line with 2
Thanks
Old Apr 29, 2006 | 05:47 AM
Patrick Campbell's Avatar
I think 2 axles should be fine, if they are rated to the weight you are carrying.
Old Apr 29, 2006 | 08:56 AM
Luke S's Avatar
Two 7k axles will be fine if you are just hauling cars or lighter vehicles, If you are hauling trucks or tractors, better got to two 10k duals, or three 7k singles. If you are hauling lighter stuff I'd recomend a low profile type in about a 36'-38' with two 7k axles. The lower profile type trailers are lighter and easier to pull than a big deck over style trailer like I have in my gallery. Also, with your old truck(like I have) your GVW is probably only 10k, so if you get a trailer with two 7k axles it'll be a 14k GVW so your combined gross weight will be under 26k and you won't have to worry about all the extra reg's, if you go three axle, or tandem 10k duals you'll be over 26k. I am over 26k and don't follow all the extra rules, but I am a rebel and I don't have any problems. It really all depends on what you are hauling. When and if the D.O.T. ever starts hassling me I will get rid of that 48' 21k gvw trailer and go back to a low profile 14k gvw 38' trailer and only haul two instead of three cause then I can get under 26k gross combined weight. Also, I run 14-ply tires even on my three axle trailer, if I were to go to two axles I'd say the 14-ply tires are extra important especially for heavy hauling.
Old Apr 29, 2006 | 02:03 PM
99 cummins's Avatar
I got a triple 7000# axle 38ft flatbed and let me tell you around town and parking lots behind my extended cab Long bed, this thing is a mother to get around. If you don't have to have that length, GO SHORTER. I can move semi's around in smaller spaces that I can this truck and trailer.
Old Apr 29, 2006 | 05:15 PM
Dieseldude4x4's Avatar
Check my album. That is a 24 foot flat with a five foot dovetail and it is plenty long for two tractors or more if stacked right.
Old Apr 29, 2006 | 05:23 PM
Fronty Owner's Avatar
Our regular hotshot pulls a 40' with dual 10K axles
Old Apr 29, 2006 | 07:59 PM
well actually im going with 38' to be exact. its either 38' with 3 axles, or 40' with 2 axles, but 38' is the minimum i can use. Mainly 99% open highway miles, loaded with about 15,000 lbs most times
Old May 1, 2006 | 08:02 AM
Luke S's Avatar
If you are talking about 15k loaded on the trailer you better get three 7k's. If you are talking about 15k gross trailer weight you could get by with two 7k's if you go to 14-ply tires. The 7k torsion axles are a little under rated in my opinion. I have consistantly overloaded them on a large horse trailer we have to no ill affects, but we run 14-ply tires also.
Sam Turner2
17
Nov 17, 2008 11:07 PM
Moobesor
Feb 23, 2008 09:57 AM
jkravito
Oct 13, 2006 05:16 AM
04ctd
Feb 9, 2006 12:04 AM
cheff
Jan 23, 2006 09:44 AM
