Will a driveshaft from a dana 80 bolt up to a dana 70?
Old Oct 12, 2008 | 03:21 PM
95black2615's Avatar
Do the driveshafts use the same u-joints....if so, is the pinion in the same location between the two (basically do they use the same driveshafts if I changed from a 70 to an 80)
Old Oct 12, 2008 | 08:41 PM
logskidder's Avatar
Nope....shaft for a 70 is a bit to long to use with a 80
Old Oct 12, 2008 | 09:42 PM
Well, I have a D70 and just switched from an auto to a 5 speed. I have a line on a rear driveshaft from a truck with a D80 with a 5 speed 4x4
Will it work?
Old Oct 13, 2008 | 07:41 AM
boughtadodge's Avatar
I just did the swap mine was a 95 auto 3/4 ton swapped all the stuff from a 95 manual 1 ton. the one ton had the dana 80 I have the 70 and they were the same u-joint it all bolted right up it might have been longer but it bolted in.
Old Oct 14, 2008 | 12:56 AM
1-5-3-6-2-4's Avatar
they'll work swap direct. I pulled the D80 out of my '98.5 and stuck in a D70 from a '95 just before i sold it. swapped the ubolt plates and directly bolted everything back in. Surely the slip yolk will handle any slight difference in the pinion length. overall slip yolk travel in a stock setup is from full compression to full droop is very little anyways.
Leaky Gasket
Dec 24, 2019 07:50 AM
horselady
May 14, 2011 08:40 PM
mowin4dodge
Apr 15, 2011 10:26 PM
Dave88LX
Dec 6, 2007 09:05 PM
