Hard to shift gears in 5 spd - why?
Old Sep 25, 2006 | 12:13 AM
Lyall's Avatar
I seem to have to double clutch a lot with my 5 spd. Its like the gears don't mesh easily. Just got my truck and am used to my " shift like butter " diesel VW. Is there something wrong with my gearbox or is the fluid inside at end of life? Any comments would be welcome.
Thanks
Old Sep 25, 2006 | 12:49 AM
West Coast's Avatar
year
What year is your truck? Does your clutch pedal feel normal? Can you shift through the gears when the truck in not running?
Dave
Old Sep 25, 2006 | 01:18 AM
Lyall's Avatar
Hard to shift -Why
Truck is a 98 2wd and the clutch is a heavy clutch - meaning that it takes a lot of pressure to push it in. Yes, I make sure that I push the clutch peddle in all the way to the floor. The shift is very difficult when the truck is at idle or turned off.
Old Sep 25, 2006 | 01:35 AM
West Coast's Avatar
clutch
You could have bad clutch pedal hydraulics.
Old Sep 25, 2006 | 02:12 AM
Allen Hibbs's Avatar
He said it is difficult to shift when the truck is off so i dont think its the hydraulics. Does the shifter feel loose or is it just hard to move it in general?
Old Sep 25, 2006 | 09:12 AM
Lyall's Avatar
Hard to shift-why
The stick moves OK but it is hard to engage (or mesh the gears ) into their proper position. It's like there is no synchromesh for the next gear. I have to clutch out of 2nd gear (for instance) to neutral , then clutch again into 3rd (and I have to push hard to engage 3rd). Same happens for other shifts either up or down in the gear pattern.
Hope that explains it better.
Old Sep 25, 2006 | 06:16 PM
clutch1's Avatar
Does it change any after you warm the fluid or run it for a while?
when you do shift into a gear do you hear any abnormal noises?
Old Sep 25, 2006 | 11:31 PM
Lyall's Avatar
No change after it is warmed up and no abnormal noises.
Old Sep 26, 2006 | 07:20 PM
9 sec camaro's Avatar
Try changing the fluid and use the oil the oil from dodge $25.00 a qt.
Old Oct 6, 2006 | 12:00 AM
mattn124's Avatar
Let me know what you find that fixes this, please. I am having the exact same trouble in my truck. 99 QC Cummins 24 valve 5-spd
Old Oct 7, 2006 | 01:24 PM
apache's Avatar
At 30 K my clutch is gone south again in the 95, this is with 0 towing/hauling and mostly freeway driving at that. Im thinking there is a pilot bearing related issue as well however there are no noises. The more its driven the harder it is to shift it seems, The oil/hyd system is OK as well. From what I read using non GL4 trans lube will eat up the syncro rings leading to the problem your having also. However in my exp every time the clutch got real hard to push it soon after was time to replace it.
Like the old boss used to say "let the problem develop".
sgrooms
21
Apr 8, 2008 11:17 AM
1ghunt
Mar 29, 2007 01:57 PM
93beater
Feb 28, 2007 09:28 AM
NCTURBOS
18
Oct 29, 2005 12:07 PM
