Grid Heaters
Old Dec 28, 2006 | 03:07 PM
taildragger's Avatar
Grid Heaters
Went to replace the grid heater solenoids on my 12 valve the other day, and noticed that when I went to drive off, that I was not charging. Got to a friends house and went to trouble shoot it and noticed that the positive line was hot, disconnected it and everything worked right.
So, what could I have done wrong. I replaced the old setup with two larger Bosch Solenoids that were self-grounded (total of four connections).
Any thoughts or ideas?
Old Dec 28, 2006 | 06:14 PM
infidel's Avatar
Pretty sure on a '98 that the control trigger to the relay from the PCM is negative, positive trigger should be present at the relay when ever the key is on run.
A grounded base relay will keep the relay on all the time.
Either isolate the relay from ground or use a non-grounded one.
Vaughn MacKenzie
32
Nov 15, 2007 04:41 PM
silverbullet02
Oct 22, 2004 11:32 PM
806 Southern In
Mar 12, 2004 06:11 AM
Hoss
16
Oct 20, 2003 09:13 AM
Cumminsdude
Mar 25, 2003 11:58 AM
