gonna replace my thermostat this weekend...
Old Jun 15, 2004 | 06:40 PM
Jeremy Cusick's Avatar
Thumbs up gonna replace my thermostat this weekend...
The old thermostat isn't maintaining the proper temps. It'll get up to 190, drop down to 160 (which is normal cycling), but then never gets hotter than 170 - 180.
I already have the thermostat and gaskets waiting on me at the Cummins dealer, but I don't know if there's anything I should know about before tearing into it this weekend.
Anything special to look out for? How much torque to retighten the housing bolts? Any exploded diagrams of this area of the engine?
I really need to order that service manual from Geno's!
Old Jun 15, 2004 | 07:00 PM
pappyman's Avatar
Really a tuff job to change stats......mite need to go to the dealership.....they have the special high tech tools for this job....and the certified stat mechanics
Old Jun 15, 2004 | 08:27 PM
Yeah right!
I'm guessing that was written tongue in cheek. So, it's that easy... nothin to worry about? What about the bolt torque? G'N'T good enough? (good'n'tight)
I timed the injection pump with no trouble, so I figure this oughtta go ok... I just wanted to know what I was getting into.
Old Jun 15, 2004 | 09:03 PM
BBWD's Avatar
Thermostat Replacement
Jerremy:
It's a piece of cake. If you can do the timing you can do this. Get the gasket with your new thermo and might think about replacing the belt at the same time while you got her down. If you haven't done the KDP it's a good time to do this also while you are in there. PM Hauling in Dixie as he can give you some suggestions on thermostats and selecting the right one. Don't remember the post but he had some trouble with one of the thermos he got from Cummins. Don't hurt to ask the people with experience.
John (DH)
Old Jun 15, 2004 | 09:47 PM
INJECTOR JACK's Avatar
Talking Thermostat!
It's so tuff that I get my pet monkey (Samboo) to do it fot me!
Old Jun 15, 2004 | 09:56 PM
Yeah, I seen HID's post. I ordered the one w/ the part # 3928499. I got this part # from the dodgeram.org site off a parts # chart for the 12 valve 2nd gens.
My belt still looks new, so I'm gonna ride that one out a whille.
Hmmm... I just found the TSb for the thermostat replacement on that site, too. Lotsa neat stuff on there.
Old Jun 15, 2004 | 11:20 PM
kandgo's Avatar
The newest thermostat part number from cummins is 3934373 and is supposed to help with the fluctuation problem, but I have yet to try one, Goodluck,,Rick
Old Jun 16, 2004 | 08:24 AM
FANZDSLPWR's Avatar
yeah it is cake. the only work involved is removing the alternater first. i got the exploded diagram from the haynes manuel. i do not have any fluctuation anymore since i put in the updated cummins thermostat. i also changed all the old coolant at the same time.
Old Jun 16, 2004 | 09:27 AM
Lightbulb Thermostat.
I don't pull the alt off, I just remove the upper bracket and then drain about 1/4 of the coolant. If your coolant hasn't been changed for a while good idea to do it now.
Old Jun 16, 2004 | 08:10 PM
Coolant is only 8 months old, and I recently added the prestone cooling system treatment to it. KDP is KIA. Cummins called today and said that my water in fuel sensor is in, too... I'll go get it all friday after work and get started!
Old Jun 22, 2004 | 12:36 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
Mine got stuck closed on my to a business meeting. (I was in a suit and tie) I keep a spare t-stat under the hood, 15 minutes later i was wheeling down the road to find a litle extra coolant to re-fill what i spilled.
Definately a technical job.
Oldschooldodge
Apr 25, 2010 10:15 PM
Bookshelf
May 30, 2009 01:17 AM
14racing
Apr 13, 2009 10:47 PM
ClackClack
Feb 2, 2007 07:46 PM
