gear swap
Old Oct 19, 2004 | 10:01 PM
Mostwanted's Avatar
gear swap
has anyone had the gears swapped? How much does this cost? Parts only cost? Thinking of just having the 4.10's with carrier swpped out with a 3.54.
Old Oct 19, 2004 | 10:11 PM
RCW's Avatar
RCW
Shop around the performance and off road guys like Randy's Ring and Pinion for a good deal. The Dana is a common configuration and parts are readily available. I would expect to pay $150 for a matched ring and pinon on a sale, and around $300 regularly.
Since you are going to have to pull everything anyway, just swap them instead of trying to install a new third member and then have to do all the bearing set-up from scratch. You will still have to adjust the carrier bearings, but it will be by thousands instead of tenths of an inch.
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
CAPTDASH
Jan 21, 2004 01:47 PM
joel
May 4, 2003 07:03 PM
Wilber1
Dec 9, 2002 01:07 AM
