who has the rod ends for my throttle linkage?
Old Oct 15, 2004 | 05:35 PM
Jeremy Cusick's Avatar
I need to know where to get new rod ends that go on the rod between the mopar linkage and hook to the injection pump. Mopar wants $70+ for a "kit the has rod ends and rod in it, and Cummins says that they don't have them (dodge said Cummins did). Does anyone know where to get them and what thread size the rod is? Has anyone switched over to heim joints?
I'm wondering when I'll hit a bump and the rod will fall off the ball stud.
Old Oct 15, 2004 | 06:47 PM
Tfeore's Avatar
Let me know what the size is, (Male/Female, LH/RH) I'll give you a part number to call a couple of bearings houses in your area. The rod that sticks out is a press fit in and probably will stay put long after you've hammered the throttle for the last time...
Old Oct 18, 2004 | 09:25 AM
earl78621's Avatar
here a picture of the throttle linkage. I can give you the Cummins Parts numbers if you tell me which ones you want.
Old Oct 18, 2004 | 09:47 AM
JFellman's Avatar
There was a safety recall on those...don't know if it applies to '95...but my '97 was fixed for free. I think the recall number is B5? Just have a dealership run an outstanding recall check.
Old Oct 19, 2004 | 04:45 PM
Dodge said all the recalls have been done on my truck.
Earl:
I need #'s 5 and 6 in the parts breakdown. I'm glad I asked about this friday, because one end fell off today right after I passed a bus. Probably Pi$$ed the bus driver off!
Old Oct 19, 2004 | 04:57 PM
earl78621's Avatar
Jeremy,
#5 is a 3931513 supercedes to 3990095
#6 is a 3931566 supercedes to 3990093
Let me know if you need any more p/ns
Old Oct 20, 2004 | 10:54 AM
JFellman's Avatar
[QUOTE]Originally posted by Jeremy Cusick
[B]Dodge said all the recalls have been done on my truck.
QUOTE]
I wonder if they are obliged to re-perform the safety recall if the same defect happens again? That was what the recall for my '97 specically addressed...same thing happened to me...front ball socket wore out allowing linkage to fall off while driving.
kris55
Nov 1, 2012 02:31 PM
oliver92
Aug 21, 2009 08:51 PM
gcliburn
Jul 18, 2007 10:21 PM
doug
May 24, 2003 08:55 AM
powerwagon440
May 1, 2003 05:20 PM
