tie rod ends
Old May 21, 2003 | 09:47 AM
doug's Avatar
tie rod ends
I've got 18,000 miles on my 02 and already have 2 shot tie rod ends. what on earth is up with that? I've been off road four times, each for just an afternoon, and terrain my grandma could drive. well except for about 15 miles total on two separate trips where I bounced around pretty good. <br><br>At this rate, I will have put the third set on just before the waranty expires at 36,000 miles, and then I'm on my own. that really sucks, of course, and I've scheduled a heart-to-heart conversation with the dealer service manager tomorrow. But really, what is going on here? did I just get bad parts off the lot (that would be nice) or is the front end really a piece of junk? <br><br>Marv says his DSS won't help the tie rod wear. What do I need to do to have a decent front end on this thing?
Old May 21, 2003 | 12:18 PM
doug's Avatar
Re:tie rod ends
I'm trying to compile a collection of after market suggestions I have is:<br><br>1. install lukes link on the drivers side of the stock tracking bar<br><br>2. install lukes link on the ends of the stock tie rods<br><br>3. install Darins DSS steering stabalizer <br><br>anything else?
Old May 22, 2003 | 09:20 AM
Dieselhead's Avatar
Re:tie rod ends
I'm in the process of buying this system. Of course I currently have 11 inches of lift up front too! Very infromative website, check it out.<br><br>http://performanceunlimited.com/stee...ngoptions.html<br><br>
Old May 22, 2003 | 11:16 AM
doug's Avatar
Re:tie rod ends
hey thats a good site. I have to say i'd rather be dealing with this problem than some of the Ford and Chevy warranty issues right now. so far the dealer seems to be working with me pretty well, too -- it pays dividends to foster a good relationthips with the service manager.
Old May 24, 2003 | 08:55 AM
Scubasteve's Avatar
Re:tie rod ends
The front end parts do not last like they should for a HD pick up truck. I have replaced all of the steering linkages on my truck but before I put them on I drilled and installed grease zerks in all of them, to prevent the boot from blowing when I purge the joint I cut a small slit in the boot where its kinda hidden and it work like a charm. Been on there for about 100k km with no problems. The type of grease you use makes a huge difference so get yourself some Extreme pressure grease of some sort ( seems to smell like gear oil) which will make all the ends last much longer.<br><br><br>Good Luck<br><br><br>Jason
ddestruel
Dec 7, 2008 06:37 AM
MnTom
Oct 25, 2004 06:03 PM
blafleur
Oct 23, 2004 03:04 PM
powerwagon440
May 1, 2003 05:20 PM
