Fuel & Oil Filter changes
Old Dec 15, 2003 | 08:33 PM
psdctd's Avatar
Re:Fuel & Oil Filter changes
Got a cat converter.....but not for long! Rip's 4" system showed up on the doorstep today! ;D
Old Dec 15, 2003 | 09:59 PM
kd460's Avatar
I would strongly advise to replace the rubber fuel lines (short 12 to 18 inch section) one is 3/8 inch and the other is 5/16 inch ID. They can allow air to enter the fuel system, and sometimes you will not even get a fuel leak. Thay dry out nd crack, just enough to let air in, but not fuel out.
I noticed a big improvement in performance by removing the cat. Mine was plugged pretty good.
Check or replace your overflow valve, check the clamps on your turbo, intercooler, and related ductwork. Also look around for ANY fuel leaks in the system.
It should not have any trouble pulling a couple (or 10) sleds. Hope this helps, Kevin
Common
19
Oct 27, 2008 06:50 PM
mr. ed
Jun 22, 2007 06:46 PM
buford
22
Dec 25, 2006 09:45 AM
Texan
Nov 19, 2006 02:01 PM
ralphie
Dec 16, 2004 09:37 PM
