Fuel Flow Question
Old May 5, 2008 | 07:27 AM
eagle523's Avatar
Fuel Flow Question
With the fuel filter off, if I push the primer button on the lift pump should fuel spill out from where the filter screws on? If it doesn't what could cause this? I can get my truck started if I have the fuel filter all the way full but then it dies in 5 seconds. I pull the filter and it has about an inch of fuel gone. I can refill and then it starts for 5 seconds again but that is it. If I push the primer button it pushes air out of the bleed valve, could my lift pump still be bad? Thanks for the help!
Old May 5, 2008 | 08:58 AM
infidel's Avatar
You could have a leak somewhere in the feed line.
Air is easier to suck than fuel.
ralphyboy
Jan 17, 2008 08:35 PM
rnb_cattle
Aug 21, 2007 05:41 PM
wrm
Feb 22, 2007 05:53 PM
8mpg
May 22, 2006 01:35 PM
Dodgezilla
15
Mar 11, 2003 07:49 AM
