fuel filter leaking
Old Aug 13, 2009 | 11:55 AM
apwatson50's Avatar
fuel filter leaking
OK, this is my dad's truck, its a 1995 and he says that the water drain on the filter is leaking. Is this a common problem? Is this valve a dealer only part? Is there a filter that you can use to replace the filter that has a regular drain in it?
I tried searching but it isn't working for me
Thanks, Aaron
Old Aug 13, 2009 | 01:57 PM
sjester's Avatar
When mine started leaking I got one here
http://www.genosgarage.com/prodinfo....31852-S-WIF-DG
Old Aug 13, 2009 | 07:14 PM
infidel's Avatar
Most times it's just a piece of crud hanging it up and cleaning is the fix.
Old Aug 14, 2009 | 08:44 AM
apwatson50's Avatar
Thanks for the info. It appears that the drain valve is the same as the 1st gens, which means i've got an extra. Just in case cleaning it doesn't work.
Old Aug 20, 2009 | 07:00 PM
Bananas's Avatar
Is the filter a Purolater? I've had problems twice with these filters. The threads that the sensor screws into on the bottom of the filter on both occasions were not square with the filter housing. This caused the sensor to thread in cockeyed to the point that the O-ring wouldn't seal. Took the filter back to where I got it and got another one. Problem solved.
Bananas!
Old Aug 21, 2009 | 09:16 AM
smokeyram's Avatar
ive had the o ring on the assembly go bad, twice. when yu change the filter and put the mechanism on the b ottom, make sure to swap the o ring, ive seen it rain fuel after trying to skip it.
jsmith2260
Apr 25, 2010 02:32 PM
BUFFALO_STEW
Dec 17, 2009 02:42 PM
diablo1
Nov 11, 2008 10:30 PM
Gumby
Jan 24, 2005 01:15 PM
