Starting in Park
Old Aug 18, 2009 | 01:13 AM
jb71054's Avatar
Starting in Park
My 97 Dodge Diesel is only starting about 1/3 of the time in Park. It will always start in neutral. I have replaced the neutral safety switch with no change. When it doesn't start in park - it will only start in neutral - I have tried moving the gear shift all the way through the gears and back to park with no luck in getting the starter to kick over. The batteries, cables and starter are all good.
Old Aug 20, 2009 | 08:03 PM
kas83's Avatar
Adjust the shift linkage. I'm battling this right now, my linkage is pretty rusty, and the bushings are worn, so I can't get the adjustment spot on.
I used a Haynes manual for the adjustment procedure.
Old Aug 21, 2009 | 09:36 AM
infidel's Avatar
See if this helps http://dodgeram.info/tsb/1994/21-24-94.htm
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
wick
Jan 2, 2003 02:50 PM
