front timing gear cover crack?
Old Oct 26, 2006 | 04:52 PM
dr.caterpillar's Avatar
I have heard there is a problem with the front timing gear housings cracking and leaking. I was just wondering where on the housing is occurs.
Old Oct 26, 2006 | 06:17 PM
JKM's Avatar
JKM
I don't have a picture handy ( i am sure someone will chime in with one) it occurs on the gear housing similar in location to where your fan hub is , that is the area to look. The crack is caused by a dowl pin than can vibrate out and jam in the timing gears , a bad bad bad situation...
Old Oct 26, 2006 | 06:55 PM
infidel's Avatar
Pictures of a typical crack here
http://cumminsdatabase.com/read.php?id=111
Old Oct 26, 2006 | 06:59 PM
Geico266's Avatar
Welcome to DTR
If it ain't broke when you buy it you can "kill the dowel" pin KDP and it won't be a problem. (If it hasn't been done already. ) About a 4 beer, 4 hour job. Pretty easy just wrenching.
Old Oct 26, 2006 | 07:02 PM
2500's Avatar
first thing after getting a 12V is to make sure killer dowel pin gets fixed.
timing cover by itself has no cracking problem, but if KDP backs out. it may or may not destroy your timing cover and/or gears.
cam has to come out to replace timing cover. you don't even want to go there...
Exekiel69
Sep 7, 2008 05:40 PM
Valv
Mar 13, 2007 08:15 PM
xtrm4xjp
21
Jul 28, 2005 10:37 PM
chevummins
Jun 28, 2005 08:48 PM
jcamron
Jan 28, 2005 08:21 AM
