Front Brake problem
Old Aug 8, 2006 | 01:01 PM
earl78621's Avatar
Front Brake problem
OK guys need a little help here! I just put new hub/rotor assys, new calipers and new hoses on a year ago. Last week I heard the indicator so I new it was time to change the pads. I pulled the passenger side tire off and the only pad that is wore out in the inner one. Yes just the inner pad seems kind of stange. All the rest of them including the drivers side still a a 1/4 inch or better left. Have any of you guys had this problem?
Old Aug 8, 2006 | 03:16 PM
Eskimo's Avatar
sounds like your caliper isn't sliding freely..need to put some grease on the pins.
Old Aug 8, 2006 | 04:31 PM
earl78621's Avatar
Ive done that. I do that everytime I put on new pads. I have even gone as far as taking the rotor/hub assy off and mounting the caliper on there and make sure it moves freely. I check it last time before replacing all the other stuff. Im tried a different type of pads this time and had my rotors turned. As much as I drive ill pull the tires off in a couple of months and check them.
Old Aug 8, 2006 | 07:21 PM
infidel's Avatar
If you want your pads to last longer grease the pins at least every 10k.
It's easy, you don't even need to jack the truck up or remove anything other than the pins if you do them one at a time.
Old Aug 11, 2006 | 02:35 AM
San Felipe Bob's Avatar
Thumbs up So true!
"If you want your pads to last longer grease the pins at least every 10k."
If you get your truck wet you may need to lube them more often.
PM me if you are tired of lubing your caliper bolts.
SFB
Old Aug 11, 2006 | 06:53 PM
Kuntry's Avatar
Anybody ever thought about drilling and inserting a grease fitting in the side of the caliper?
Old Aug 14, 2006 | 04:44 PM
Kuntry's Avatar
*****btt*****
Old Aug 14, 2006 | 06:39 PM
infidel's Avatar
It could be done.
Bet the reason it isn't done stock is because the engineers figure many people would over grease them and foul their pads up
wannadiesel
Nov 1, 2013 06:58 PM
oldblu
Nov 10, 2010 08:59 PM
EatMorePossum
May 1, 2010 02:13 PM
johnls
Apr 1, 2009 01:51 PM
dogman
Dec 27, 2003 07:06 PM
