Exhaust brake quite working?
Old Jul 12, 2011 | 11:22 PM
9MM's Avatar
9MM
So a while back dads 96 5 speed with the BD diesel exhaust brake quit working we traced the problem to the vacuum valve thing above the valve covers I dunno the proper name for it but it allows vacuum to the exhaust brake when it gets a 12v signal.
We checked it out and it has power to it and vacuum to it but no vacuum out. I can not find a replacement anywhere and BD diesel never got back to me on a if they make a replacement or not so I was wondering what you guys do in this case as I can't see this being a super rare thing.
Old Jul 13, 2011 | 09:36 AM
rebal's Avatar
you should be able to use any 12 volt vac. switch and make it work. lots of gas engines use vac switches
Old Jul 13, 2011 | 09:48 AM
torquefan's Avatar
It's very common for the spool valve to get gummed up, and it just needs to be disassembled and hosed out with WD40. The end plate comes off with 2 little screws, and get ready to catch a small spring behind the plate. Twist out the spool valve with a pair of pliers gently, then clean up the spool and bore until the spool moves through with no effort.
You may just plan to do this every 6 months as preventive maintenance.
Old Jul 13, 2011 | 10:15 AM
infidel's Avatar
This is for a PacBrake but is the same idea> http://pacbrake.com/PDF/L5223.PDF
Old Jul 13, 2011 | 11:41 AM
9MM's Avatar
9MM
Okay I can't seem to find replacement switches.
Okay I'll show my dad how to clean that valve.
Old Jul 13, 2011 | 02:19 PM
Hector-BD's Avatar
Vendor - Former Vendor
99% of the time, all you need to do is clean the solenoid. If the coil doe's not have a dead short and the internal body is the issue, even after cleaning it, the repair kit is a part number 1230101.
If you have any other questions please feel free to contact me.
Regards,
Hector
Old Jul 13, 2011 | 04:49 PM
enhartiii's Avatar
Exhaust brake spool valve probably stuck
Most spool valves are inexpensive and easy to repair/clean. Be careful not to damage or lose the o-rings in the spool. If a replacement valve is required, try Banks Power. I have a Banks exhaust brake and they probably will sell just the valve or at least tell you where to get one.
Old Jul 13, 2011 | 05:03 PM
Hector-BD's Avatar
Banks uses a completely different vacuum valve the only two that are interchangeable are the BD & Pac vacuum solenoid valves. every other component of the brakes are differrent for this model year truck.
Old Jul 14, 2011 | 11:32 PM
9MM's Avatar
9MM
So I told him last night so today he took it apart said the plunger piece wouldn't even move so he cleaned it out n now his exhaust brake works again.
Thanks guys.
CRXsi
Oct 30, 2007 10:54 PM
Zeus
Jan 23, 2007 05:50 PM
prohan007
Aug 21, 2006 12:16 AM
nxpress
Oct 15, 2004 12:10 PM
MnTom
Dec 5, 2003 04:21 PM
