Quite Exhaust with Good Flow
I have a 03 Ram 2500 5.9 SO with Edge Juice w/attitude, K&N air intake.
I need to upgrade the exhaust to something better as I want great performance but I want to keep it as quite as possible. Any thoughts ??
I also have a question on trans temp guages, my Edge Attitude does not monitor the trans temp and I need recommendions to resolve this??
Thanks, Phil
Thanks, Phil
Nelson 51"
Hey there, after using the search button on numerous occasions I put a 51" Nelson muffler on my 2004.5, and I am very pleased. I paid $65 dollars for the muffler and $25 dollars to be welded up professionally. It sounds like stock at idle just a little deeper. At highway speeds sounds totally stock. When you lay into it lets out a deep growl that turns heads..... the best of both worlds! I am not old I just have had all types of mufflers (Flowmaster, Borla...etc) and have come to the conclusion that I don't want the interior noise all time. Very cheap upgrade that you will be happy with..maybe alittle better fuel economy to boot. Do a search on the Muffler part number then find a local 18 wheeler parts dealer which you can usually find in most towns. Give them the part number and they probaly can order or even have them in stock. Later.
My Banks exhaust fit great, has a little more noise but hardly noticable in the cab. I ended up with is after I tried a 5" Magnaflow which was way too loud for my taste.
Also you shouldn't need the tuner to monitor the trans temp, if your towing keep an eye on it but I think the only system out that even monitors trans temp is the Banks with the PDA. Everyday driving the trans temp shouldn't be an issue. Good luck!
Originally Posted by jon05ctd
Where did you buy the Nelson muffler?
Did it fit on the stock exhaust system and line up well?
Thanks Jon
Thanks Jon
Ok I forgot to add that one of the main reasons for just adding the muffler and not the entire aftermarket exhaust is because my 2004.5 has a 4inch exhaust from the turbo. Also if I ever upgrade to twins or a bigger turbo I won't be out tons of money when I go up to a 5inch exhaust. Who knows I my never go up...these trucks have mad power!
I put on the 51" Nelson and it was a little louder than stock. It was loud enough to drown out all the drivetrain noise but the bad thing was, it sounded like a trashcan. Higher rpm with my 4.10s was really irritating. So, I got a pack of fiberglass insulation and packed the chambers, completely wrapped the outside and covered it with more sheetmetal (I also do sheetmetal work). Now I have an 11" dia. muffler-in-a-muffler and it really IS as quiet as stock. I love it - the only thing I hear is a deep rumble from the tailpipe. Craig
Trash Can sound
That's funny "Trash can"
Mine sounds great but maybe because I have 3.73's and the RPM's are not as high. What does a trash can sound like?
Anyways different strokes for different folks.
ralphyboy
Jan 17, 2008 08:35 PM
Zeus
Jan 23, 2007 05:50 PM
8mpg
May 22, 2006 01:35 PM
