Engine oil in the downpipe
Old Jul 26, 2007 | 11:06 AM
ric o'shea's Avatar
I just finished installing a turbo back 4" aluminized MBRP exhaust. After starting the engine I found a exhaust leak at the downpipe clamp connection.
The clamp wasn't tight enough, so I figured to take a 8 mile drive to enjoy the new sound and tighten it later.
When I got back and crawled under the truck to tighten the clamp I noticed engine oil had seeped from that same connection. Well that made a great day go south very fast.
I was hoping it was residual oil from the manufacturing process. But I know it is not. Cylinder rings shot? turbo oil seal? Where to start?
Old Jul 26, 2007 | 11:13 AM
dieselfuelonly's Avatar
DTR question asker
I would think the place to start would be the turbo. Hopefully its an easy fix!
Good luck!
DFO
Old Jul 26, 2007 | 11:24 AM
CarlJensen's Avatar
You can also pull off the intercooler boot at bottom of the pipe going up to the intake to check for any oil there. If you have a leak problem with the turbo it can be rebuilt with a kit. Go to the link for kits. Not hard to rebuild yourself.
http://www.htturbo.com/hp.html
Old Jul 30, 2007 | 01:33 AM
ric o'shea's Avatar
I have been driving the truck alot with the clamped connection still leaking exhaust.
I am starting to think that possibly the black oil I did find was from the tubing bending/coating process pooling at the bottom of the down pipe connection. Then it mixed with the exhaust soot and turned black and seeped out.
There was quite a bit of oil on the inside wall of the tubing I noticed as I unpacked the exhaust from the box.
All that is visable now is exhaust soot where the connection is leaking, no sign of any oil. I am keeping my fingers crossed
Now it's time to secure the leaking connection and enjoy.
ClassA4x4
May 16, 2013 11:49 AM
97catintenn
Jul 12, 2009 05:33 PM
KatDiesel
Jun 2, 2003 12:11 AM
97CTD
Feb 4, 2003 03:05 PM
patriot pearl blue
Dec 15, 2002 12:10 AM
