Engine Dies At Least Excuse
Truck is a 1997 with automatic, basically stock.
Regardless of temperature, engine cold or hot, engine starts easily and immediately dies, fires right back up and dies again.
Once it decides to run, while driving along, gun the throttle the least and it dies again.
What are the possible culprits.
Thanks.
Thanks.
Cummins Guru
Sounds like your rpm is too low at idle. 10mm wrench needed to loosen locknut and turn adjusting screw at injection pump lever at the rear of injection pump. Adjust to 750 rpm in gear with ac on, engine at operating temp. Adjust low rpm only, to the right of the high rpm stop.
Cummins Guru
Usually will cause a stalling condition cold more then hot but also depends on how low RPM is when hot. If too low just adjust it to proper RPM.
Big Rig
11-23-2006 12:51 PM
streetsmoker
09-05-2006 07:59 PM
rico334
08-10-2005 07:53 AM
