exhaust springs?
exhaust springs?
when i bought my truck, the owner before had an exhaust brake on it but removed it prior to the sale. i didnt think about asking him at the time, but do you guys thinks that it might still have the upgraded exhaust springs on it?
if so, how can i check if they are in there or not? thanks
I am not sure. But I think the factory intake and exhaust springs were probably identical. With that in mind, you can try compressing and intake spring in place and compare it with an exhaust spring in place.
Aren't the heavier springs rated at like 60#?
Ronnie
Ronnie
I can't imagine taking the springs out, they don't cost that much and reusing them makes no sense. What brand of EB did he have? My Jacobs brake came with 60 lb springs, but as far as I know, the other brands did not. Cummins (who own Jacobs) recommended no EB on trucks with autos and did not sell a kit for them. A freind of mine has an EB and has not changed the springs. The stockers are 40 lb so I would guess you could remove a couple and check their tension.
I digress. You need to look into why the EB is not recommended for the early auto trans.
wouldnt downshifting cause the TQ converter to lock up?
or how would i be able to manually lock it up?
ill look into why EB might not work on early trannies,
thanks
thanks
I don't know, about downshifting. I have heard on another forum about a "mystery switch" used to increase line pressure for lock-up, but I can't tell you how that works either.
Originally Posted by GAmes
That is true, but not an absolute. As stated, a friend of mine has an EB with the stock springs (5-speed) and he is satisfied with it.
Your friend is simply considered a luck guy here that he hasn't damaged anything, and no way would I go around telling folks it's okay.
94ram,
The only way to tell what springs you have is remove a couple of valve covers. The 40 lb springs are consistantly the same diameter as the top spring retainer caps, the 60 lb springs are fatter and bulge out in middle like barrells, so the diameter is going to be bigger than the spring retaining caps.
The brakes on auto's weren't recommended by Cummins, simply because Cummins had no idea how to force lock up in the converter. Get a BD Autolock or Torqloc kit...they will keep your converter working properly with the brake, and are set to kick-out when you slow to a desired mph.
You cannot down shift to force lockup, anytime you take your foot off the throttle the TPS tells the computer to unlock, simple as that.
Sorry, that is false information being given out. You could probably get away with stock springs using a Jacobs brake, because Jacobs develops the lowest back pressure of all the available brakes on the market. However A properly set BD or Pacbrake will create more back pressure (better braking power) than the 40 lb springs can take.
Let's see. A. It is not false information. He has an EB (either a pac or BD, not a Jacobs for sure), has not installed 60 lb springs and he is satisfied. That was a true statement. FWIW he tows a very heavy Montana 5er (full time RVer), mostly in the western states.
B. I find it ironic that you consider it OK to use a Jacobs without HD spings and they are the only ones who include the springs in the EB kit. I asked my friend about that and he told me that according to his installation instructions the 60 pound springs were not required.
C. Based on my friend's truck and what he told me I stated to the OP that what he heard was true (according to what I know about mine) but not absolute (based on my friend's info).
D.In summary, there is no guarantee that there are 60 lb springs in the OP's engine. I didn't say it was OK, I just stated the obvious.............which you missed.
Not a good copy, but here is a link with diagram and other info for a mystery switch.
http://www.turbodieselregister.com/f...ire-where.html
my 96 auto has pac brake and I ran a tc lock up swith for a long time. it worked ok. I made it into a 5spd last year and love it now. I talked to dave gorend about it when the tranny went out and he said that inorder to run a EB on a auto you have to have a custom valve body built for the tranny. someting about one of the rods in the VB would get bent over time if not upgraded. maybe give him a call and ask him what he thinks.
DM01
DM01
An orginal fixed orfice brake without the heavy valve springs was ok to use, however the braking was so/so and in an automatic it was a little worse then so/so (depending on how heavy you towed) we did reconmend heavy springs and locking up the TC for the best braking effect. Not everyone chose to have the springs install or use a mystery switch. As for our PRXB you have to have the heavy spring in the engine and the TC locked up.
I never said it was okay to run a Jacobs or any brake with stock springs, you were the one who said it was okay because your 'buddy' had no problem with his. You said and I quote "but not an absolute" in OP's question to spring swap.
I've installed countless exhaust brakes over the last nine years...always always always use 60 lb springs! I know Jacobs includes them, but in every BD instruction manual I've seen since 1999, they say 60 lb springs are required, not optional.
I know you based your answer on your buddy's truck...one truck, but no way would I gamble with the 30-40 folks I helped out.
That's funny, since every automatic transmission shop in the country had at least one tech who knew how to get the TC to lockup.
I don't know what that weakness is, and it is pretty obvious you do not either
I'm not allowed to say where I work (forum rules), but I can say that I do this everyday.
whoa there fellas
no need for anyone to get mad at anyone else. we are here to help each other out right?
its all good we put up good info but theres no need to argue
