DIES at start up
Old Aug 7, 2010 | 07:22 AM
xdjscri's Avatar
Exclamation DIES at start up
At the first start up in the morning, it starts fine then after about 30 -40 seconds , at idle, something happens then it dies. It then takes a few minutes(3-5) of cranking/starting again to get it started. After that it runs fine all day. It seems as though something "clicks" on or off during the initial 30-40 second period then somehow recovers after that. It's a '97 2500. Thank You
Old Aug 7, 2010 | 04:19 PM
mechmagcn's Avatar
Lift pump is letting fuel drain back, replace it and the problem will go away.
Old Aug 7, 2010 | 04:57 PM
xdjscri's Avatar
Thanks mechmagcn. But why does it start fine the rest of the day after that first troublesome start up?
Old Aug 7, 2010 | 08:24 PM
Dojman's Avatar
Unless I saw the lift pump leaking, I would check or replace the rubber fuel lines first, but that's just me. It may be that you are starting it more often during the day (versus the hours overnight undisturbed), and it doesn't have time to lose prime. The original set of rubber fuel lines on mine wouldn't leak fuel, but would lose prime overnight. Eventually, it did start to leak when it was running, once the dry rot cracks got big enough.
vintovka
Apr 30, 2012 12:38 PM
90 power ram
Oct 6, 2011 08:04 PM
Palmetto_kid
Mar 31, 2005 02:01 PM
IntakeRacing
Dec 10, 2004 08:20 PM
Rockyhud
May 24, 2004 09:44 AM
