dana 80 carriers
Old 02-07-2005, 06:13 AM
gwhammy's Avatar
dana 80 carriers
Is the carrier for the 350 gears different than the 410 carrier. I know dana used to do this. Thanks Gary
Old 02-07-2005, 07:59 AM
dodgenstein's Avatar
Yes, the 4.10's use a different carrier.
Old 02-07-2005, 04:18 PM
gwhammy's Avatar
I was afraid of that, all the other dana's I have fooled with broke ratio at around 3.70. That makes it more expensive, by the time you buy two carriers and two gear ratio sets it might be just as cheap to add an aftermarket add on overdrive. My buddy is running a 98 cab and chassic with a five speed and said it turns way to tight on out on the interstate. Ain't many ways to go with a dually as far as tall tires.
Old 02-07-2005, 04:50 PM
gunracer1's Avatar
my buddie just used a 4.10 lsd carrier and put on a set of 3.55s in his truck[dana 80]. i belive the carrier break is 4.10 and down, and 4.56 and up. this was on dually dana 80's one 1994 model the other was a 97 model. the swapped between each other just fine.
Old 02-07-2005, 05:26 PM
gwhammy's Avatar
Who sells gears for the dana 80, I looked in one gear supplier I use alot and they don't list any gear for the dana 80. What about the 60 in front, is the break on ratio size the same as the 80? Is the 80 like the rest of the dana's where you need a case spreader to get the carrier in and out and use shims behind the bearings to set them up.
Old 02-07-2005, 07:30 PM
On the 60 the break is between 4.10 and 4.56.
RickG
12-07-2007 10:44 PM
ccoop769
09-29-2007 07:22 PM
nobull60
08-25-2007 06:52 AM
dws35
04-18-2006 07:33 AM
Quick Reply: dana 80 carriers
