Dana 70 nut torque
Old Sep 21, 2005 | 07:43 PM
infidel's Avatar
Question Dana 70 nut torque
Anyone know how much to torque the 2-9/16 nut down to when replacing the axle seal?
Old Sep 21, 2005 | 08:02 PM
VPI's Avatar
VPI
If you are talking about the pinion seal that is behind the yoke on the rear diff then I just did mine. The Hayse manual said 440 to 500 ft-lbs. I had to borrow a torque wrench for a friend that works on heavy equipment. Hope this helps and I hope i am answering your question. Opps that is for the 80 for the 70 the book says 220 to 280 sorry .
Old Sep 22, 2005 | 12:10 AM
infidel's Avatar
Thanks, I meant the the axle end nut.
Found it 120-140 ft/lb and back off 1/3 to 1/8 turn.
Old Sep 22, 2005 | 04:42 PM
VPI's Avatar
VPI
Sorry I took the 2-9/16" nut as a 2 and 9/16" nut not Two 9/16" nuts. I guess I should only respond when I have been drinking
Old Sep 22, 2005 | 06:42 PM
infidel's Avatar
It is 2 and 9/16, there is one at each rear wheel
Old Sep 22, 2005 | 08:39 PM
VPI's Avatar
VPI
Let's do this a few more times I may get it.
Old Sep 23, 2005 | 10:28 AM
infidel's Avatar
If the nut behind the pinion is also 2-9/16" that means there are 3 2-9/16 nuts, not one 32 and 9/16"
Old Sep 23, 2005 | 11:03 AM
95black2615's Avatar
I tried that torque setting method a couple months ago on mine and it seemed too tight, so I backed mine off more.
Let me know how yours feels with the book torque specs.
Old Sep 23, 2005 | 08:02 PM
jimk's Avatar
end clearance
Bill I read a good while back that the hub needs from .001 to .010 end play with a dial indicator. I hope this helps Jim
Old Sep 23, 2005 | 08:10 PM
G1625S's Avatar
Yeah, I tried to do it the 'right' way and it felt too tight...maybe wore out, pitted up races. I like the dial indicator method---lubing with 80-90 means there needs to be some space in there. Time to brush off the dial indicator and check.
g
wisconative
May 13, 2013 07:20 AM
Clane
Jun 2, 2012 03:31 PM
mullishacrew
Nov 24, 2011 03:39 PM
Firstgenfanatic
May 14, 2008 06:17 PM
bkoz
Feb 22, 2008 09:21 AM
