creature pounding on my floorboard
Old Jun 25, 2007 | 07:33 PM
siebertl's Avatar
Can't find what is causing the noise. It only happens when I'm underway and turning. I get a thunk, like someone hit the floor board on the passenger side w/ a hammer. I will hear it once when I turn left, then again when I turn right, etc. etc. Any Ideas which compenent is loosened up?
Old Jun 25, 2007 | 07:58 PM
clutch1's Avatar
is it on full lock? check the thread on the differential prob.
Old Jun 25, 2007 | 08:41 PM
satburn's Avatar
This reminds me of the BobandTom skit with Mr. Obvious and the garbage disposal...
Anyway, I'd start with the track bar where it mounts to the frame.
Old Jun 26, 2007 | 09:15 PM
TIMMY22's Avatar
a "popping" sound while turning the wheel back and forth usually is the track bar ball stud.
a "ratteling" under the floorboard while driving is was the lower shock bolts for me.
Old Jun 26, 2007 | 09:29 PM
jlipskoc's Avatar
Check the lower ball joints, mine did the same thing, since the control arms connect beneath the body mounts, he sounds like just as you described. My stock ones went bad at 134k. I have greesable Moogs now, top and bottom bj and new ujoints, zero noises.
Old Jun 26, 2007 | 09:44 PM
yoshimura's Avatar
It sounds like the track bar to me also.
Old Jun 26, 2007 | 10:18 PM
kawi600's Avatar
I get this too even with a thuren bar and the ball stud really tight on the mount. Heck if I can figure it out
Maybe turn the wheel and have someone watch the parts to see whats popping
t8ter
Jul 5, 2006 10:47 PM
justagoodolboy
Jun 22, 2006 06:00 PM
dodgediesel4x4
Mar 8, 2005 06:06 PM
LarryJ
Jan 11, 2005 07:10 PM
2k1yzfr1
13
Dec 3, 2004 09:43 PM
