boost ? from a newbie
Old Mar 29, 2005 | 08:12 PM
onelugnut's Avatar
I did a test drive on a 96 today.I noticed that when I put my foot in it the boost gauge maxed out on 35 Is that normal?
This truck has had some go fast goodies done to it.
new injectors not sure what ones or the size.#8 plate,4 inch exhaust,and a high flow air filter with the stock box,
Please be easy on me I am very new at diesel stuff
Old Mar 29, 2005 | 09:07 PM
Big Perm's Avatar
I understand that it is not uncommon for a stock truck to hit 35, though it's usually around the low 20's.
Maybe you need a gauge that has a 60 max psi
Oh, and fill out your sig line w/ what you have and what's done to it. Helps though who can actually help
Old Mar 29, 2005 | 09:16 PM
onelugnut's Avatar
Thank you for the info I was worried that it may have too much boost.
I have no info yet.I have no truck untill the weekend If I put I have a 94 F-250 gasser I may get banned
Old Mar 29, 2005 | 09:31 PM
Eskimo's Avatar
With that plate, 35psi is fine.
Big Perm missed that it has a plate in it.
Worry more about Exhaust gas temps.
Old Mar 29, 2005 | 09:38 PM
onelugnut's Avatar
Sorry for the dumb questions.Is that the same as the pyro temp?
I am planing on using this truck to pull a 10,000 pound toy hauler.The man I am buying it from said the pyro temp will go to about 900-1000* with his toy hauler going up some of the larger grades.
Old Mar 29, 2005 | 10:43 PM
CarlJensen's Avatar
Yep,same thing. 1000 is fine you just don't want to take it past 1300 or so for any length of time while pulling. That temp should be pre turbo location of the probe. Hah,,banned! Not here, this is not THAT site!!
Old Mar 30, 2005 | 09:50 AM
infidel's Avatar
You need to find out if the pyro probe is mounted pre or post turbo.
If it's post 900-1000° is getting very close to the danger point and could even be exceeding it as in the post location the gauge is slower to react.
900-1000° sounds too low in pre turbo location with the mods done on this truck plus a hill and trailer.
35 psi boost is just fine but you probably don't want to go any higher.
Old Apr 1, 2005 | 08:59 AM
onelugnut's Avatar
Thank you for the info. I got the truck last night and the pyro probe is after the turbo.What should my not exceed temp be and how do I get the temps down
Old Apr 1, 2005 | 10:10 AM
infidel's Avatar
Generally the post turbo temp is about 300° lower than the pre temp but this doesn't always hold true. People who have a probe in both locations say that it's very inconsistent and the difference can sometimes jump up to 400° difference between locations.
That's the big reason it's recommended that the probe be installed pre-turbo especially on a modified rig. You might want to consider moving the probe.
To lower egts the engine needs to breath better. According to your description of the truck and assuming the cat is gone about the only thing missing is a larger turbo housing or different turbo. You can also slide the plate back a little to reduce egts but you will lose power also
Old Apr 1, 2005 | 12:36 PM
ride_a_hd's Avatar
Here is a guy who had a pre- and post-turbo pyro and used a toggle switch to check one then the other. Enjoy your new ride, and like some will say, "no such thing as a stupid question." If you have a question, ask. Better to do that and not risk damage to your new truck!
Dave
http://gatewaydieselownersassociatio...y=1&how_to=EGT
Old Apr 1, 2005 | 06:41 PM
onelugnut's Avatar
Thanks for the link ride.That will be the first thing I will do to the truck It doesn't look to hard to do.
Old Apr 1, 2005 | 10:14 PM
ride_a_hd's Avatar
Any time!
Old Apr 2, 2005 | 08:16 PM
bmoeller's Avatar
Turbocharger FAQ
ShouldBFishin
Jul 30, 2008 02:14 AM
GTSDave
Jul 8, 2005 09:06 AM
MY WORLD
25
Dec 29, 2004 08:54 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
mkiv_tt
16
Sep 17, 2003 01:00 PM
