Blow By
Blow By
I've been noticing that I'm getting what looks like a steam mist coming from my vent tube. It's not a heavy mist, but it puts a thin coat of oil around my oil pan and front driveline. Truck has 144,000 on it. Is this something that I should be concerned about? I use about 1.5 to 2 quarts of oil every 4,500 miles.
Re:Blow By
check out the post about replacing the vac pump seal
. Im gonna replace mine soon. Ive been getting enough blow by to cover the under side and tailgate of my truck
. I dont think there is any real damage as long as you keep enough oil in her
.<br> Wheels<br>
.<br> Wheels<br>
Re:Blow By
[quote author=dsljunkie link=board=16;threadid=13581;start=0#127876 date=1050333028]<br>check out the post about replacing the vac pump seal
.<br> Wheels<br> <br>[/quote]<br><br>That kinda leak is not blowby it's just a bad oil leak.<br>Blowby is compression blowing by the rings causing the oil mist to blow out the vevt.<br>Hence the name BLOWBY<br><br> : Eddie : 8)
Re:Blow By
If the lift pump is bad you will either get fuel in the oil [ oil level on dipstick will rise ] or it will leak on the ground.<br>Thats what mine did 2 weeks ago and it was intermitten for about 2 months.<br><br> : Eddie : 8)
Re:Blow By
[quote author=Turbowd link=board=16;threadid=13581;start=0#127768 date=1050290802]<br>I've been noticing that I'm getting what looks like a steam mist coming from my vent tube. It's not a heavy mist, but it puts a thin coat of oil around my oil pan and front driveline. Truck has 144,000 on it. Is this something that I should be concerned about? I use about 1.5 to 2 quarts of oil every 4,500 miles. <br>[/quote]<br><br>If your using that much oil I would be finding the prob.<br>I change oil every 5000 miles and it doesn't use a drop [ knock on wood ] :-X<br>And I run my truck pretty hard working and playing. :
<br><br>I bet you got a leak somewhere. <br>Look real close at Afc housing, vac. pump ,ect.<br>There is prob a little prob that looks big.<br><br>GOOD LUCK !<br>Keep us up to speed on what you find.<br><br> : Eddie : 8)
Re:Blow By
The two things I did to cure oil leakage was replace the gasket between the vacuum/power steering pump assembly and the block and hang a small vitamin pill bottle on the end of the breather tube. No drips now!!
Re:Blow By
Sides of the block are dry UNTIL I get to the oil pan. Some of this appears to be coming from it, if not all of it. I need to check my rear main too. Any slick ideas on how to replace the pan gasket?<br><br>Thanks
Iron Horse
Feb 12, 2003 10:51 AM
