block heater quit workin
Old Dec 27, 2002 | 01:01 PM
bigbaddiesel's Avatar
My block heater no longer works. I left it plugged in all night then in the mornin it was hard to start. I know the outlet and cord are good (they run the x-mas lights.) Is there a fuse? Maybe i have a short. I only backed out of the driveway once without unplugging it. I know because when i got home, the cord was almost out to the street. Any body else ever have a problem with thier heater?
Old Dec 27, 2002 | 01:56 PM
pappyman's Avatar
Re:block heater quit workin
The biggest problem is the cords on these heaters check it with a ohmn meter...disconnect the cord at the heater and check it with a ohmn meter....if that checks ok the chances are the heater is bad
Old Dec 27, 2002 | 03:53 PM
richard's Avatar
Just in case your cord or heater are bad,here are a couple of cummins part #s<br>cord 3923050<br>block heater 3940911<br>hope this helps.
Old Dec 27, 2002 | 05:31 PM
whiteknight's Avatar
mine had broken wire under isulation at the plug 8) 8) :P :'( :'(
Old Dec 27, 2002 | 07:33 PM
thanks for responding. Now i have some direction to start looking.
Old Dec 28, 2002 | 01:44 PM
greatwhite's Avatar
Check the wire where it goes into that stupid molded plug. Thats the most likely place for a break. If its cracked or broken there, just buy a good HD male cord end at your local hdwr store and replace it. HTH Rick
Whoanow
Nov 4, 2009 05:12 PM
supersonictoys
Nov 8, 2008 09:17 PM
deezel
Mar 12, 2005 10:14 AM
Smokedawg
Feb 10, 2004 10:54 AM
Redleg
Jul 5, 2003 12:18 AM
