auto transmission swap
Old Oct 14, 2006 | 11:45 PM
dodgedawg's Avatar
anyone know if i can do this and what parts will be needed and changed,
i'd like to swap a transmission out of a 2001 probably a 47re into a 1996 which might have a 47rh in it, not sure if the model numbers are right and both trucks are 4x4, the 01 a reg. cab and the 96 an ext. cab
a bubby of mine has the 2001 and is swapping a six speed into his this coming weekend, so i can get everything coming off the truck like the flywheel, trans, and transfer case then right now my trans has losted OD and has alot of metalic brass particles in the fluid,
thanks for any help
Old Oct 15, 2006 | 12:58 AM
AAmeeting's Avatar
It wont work. ECM wont interface rh is hydraulic re is electronic with various sensors missing It would be easier to sell that one and buy a rebuild.
Old Oct 15, 2006 | 03:20 AM
PourinDiesel's Avatar
A friend of mine installed a tranny from a 96 into his 01...he had to change the sensors on the valve body and wire harness.
Old Oct 15, 2006 | 06:36 AM
JD730's Avatar
A 96 will have a 47RE and yes like PourinDiesel said, your going to have to change all the sensors and the wiring harness in the trans.
Old Oct 15, 2006 | 09:40 AM
dodgedawg's Avatar
ok, looks like it can be done by just putting sensors and a wiring harness in,
so can i take the sensors and wiring harness out of the 96 transmission and put these into the 01 transmission,
thanks for the help guys
Old Oct 15, 2006 | 03:19 PM
Ironstone's Avatar
My 96 has an RE in it. Check under your hood (there is a tag) it will tell you what tranny you have.
kit
Mar 2, 2010 07:04 PM
HONDA99
Oct 10, 2009 07:45 AM
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
