auto transmission swap
anyone know if i can do this and what parts will be needed and changed,
i'd like to swap a transmission out of a 2001 probably a 47re into a 1996 which might have a 47rh in it, not sure if the model numbers are right and both trucks are 4x4, the 01 a reg. cab and the 96 an ext. cab a bubby of mine has the 2001 and is swapping a six speed into his this coming weekend, so i can get everything coming off the truck like the flywheel, trans, and transfer case then right now my trans has losted OD and has alot of metalic brass particles in the fluid, thanks for any help |
It wont work. ECM wont interface rh is hydraulic re is electronic with various sensors missing It would be easier to sell that one and buy a rebuild.
A friend of mine installed a tranny from a 96 into his 01...he had to change the sensors on the valve body and wire harness.
Originally Posted by PourinDiesel
(Post 1166588)
ok, looks like it can be done by just putting sensors and a wiring harness in,
so can i take the sensors and wiring harness out of the 96 transmission and put these into the 01 transmission, thanks for the help guys |
My 96 has an RE in it. Check under your hood (there is a tag) it will tell you what tranny you have.
