afc
afc
ok being new here excuse my ignorance. if i slide the afc housing and fuel plate all the way forward and adjust star wheel to the front of truck i should get more hp and smoke right?<br>do i need a pyro gauge?<br>i'm doing exhaust also
Re:afc
[quote author=js link=board=16;threadid=10489;start=0#100202 date=1044331893]<br>ok being new here excuse my ignorance. if i slide the afc housing and fuel plate all the way forward and adjust star wheel to the front of truck i should get more hp and smoke right?<br>do i need a pyro gauge?<br>i'm doing exhaust also<br>[/quote]<br><br>Yes it will give you more HP and definately more smoke, but I would STRONGLY advise against doing so until you get an EGT guage first!
Re:afc
Re:afc
Hey js,<br>The Star Wheel only controls fueling until the turbo can spool up to provide boost.<br>Adjusting the Star Wheel will get you more fuel at low rpms (More fuel = more smoke. More fuel = more power).<br>Yes, it will increase EGT's but only until the turbo can spool up. <br>Once the turbo is providing boost, the star wheel no longer affects fueling.<br>Also, if your not heavy with your right foot, the smoke isnt too bad... nor will your EGTs be bad.<br>If you floor it from a stop, then yes, you will notice a lot more smoke.<br><br>However, ANYtime you change your fueling rate... you should invest in an EGT guage.<br><br>Rich
Re:afc
thanks for the replies. i figured i would put a gauge on it.<br>i just want a little more power but like to keep my truck pretty well stock
royta
02-15-2005 10:15 PM
Dusty 96
11-05-2002 01:45 AM
