Added lift pump, Truck won't start
Old Apr 26, 2008 | 01:28 PM
whitediesel's Avatar
So, I added an electric lift pump from bd and now the truck wont start . 97 12v, 270,000 miles no mods. Overflow valve? or fuel shut off solenoid?
This is not the truck in my sig Please help
Old Apr 26, 2008 | 01:33 PM
Common's Avatar
OK, did you see if the fuel filter is filling up?
Did you crack any injector lines?
Old Apr 26, 2008 | 01:41 PM
did not crack any lines but filter is draining
Old Apr 26, 2008 | 01:42 PM
i can make the truck run if i hold donwn the throttle, but only for a minute then it dies did this 20 times
Old Apr 26, 2008 | 01:47 PM
Common's Avatar
What made you add the electric lift pump?
Were there problems before this was added?
Old Apr 26, 2008 | 01:55 PM
the ticking noise made me think the lift pump failed and i already had the electric lift pump
Old Apr 26, 2008 | 02:46 PM
John Faughn's Avatar
You need to back up , the mechanical lift pump in that truck is for the price & general use , the best / most reliable you can get .
Ticking can be a sign of an issue is the only way to find & fix a problem , if you want to do it right , for the least money / effort .
Then & now a fuel pressure test , 26 psi at idle , and 35 at wide open throttle , not more than a couple lbs lower than those numbers .
If pressure is low , slowly pinch the return hose , watch to see if pressure goes up , if it does then new OFV , if not , the pump may not be able to make pressure .
Old Apr 26, 2008 | 06:38 PM
infidel's Avatar
More than likely your electric pump isn't putting out enough pressure.
Replace with a mechanical pump from Cummins, about $70.
Old Apr 27, 2008 | 06:42 AM
but why would this happen only after i added the electric pump? even if the electric pump isn't putting out enough pressure it would still be more than it had before and the truck ran fine before that.
Old Apr 27, 2008 | 09:47 AM
I thing you missed the point , the old [ no fuel pressure test ] just ticking may have been making good pressure .
Then you put in an other pump [ stlll no pressure test ] , now you have a new problem , odds are , the change in performance is from the change you made with out testing before or after .
The ticking would have been a good reason to test the old pump , now you have a reason to test the new pump .
Testing saves more money than parts .
ado2b1
Dec 16, 2008 03:19 PM
deerslayer1979
Nov 11, 2008 08:01 AM
stock600
Apr 8, 2008 11:30 PM
thanasi
Jan 15, 2007 09:53 AM
kd5wqk
Nov 3, 2003 02:06 PM
