215 HP P-Pump Identification....How to ID??
I purchased a 1997 Dodge 2500 yesterday and the tag is missing from the timing cover.
Any ideas how to Identify the p-pump?
I HOPE it is the 215 HP engine.....
how to ID the engine and the pump....
thanks guys!
thanks guys!
Is it possible that the tag cannot be seen unless the linkage plate is removed?
There is a slight gap where you can look down and see if there is even a tag there.
I could be wrong...
The data plate is missing from the timing cover. This is why I am trying to ID the pump.
Possible the dowel pin may have killed the timing cover and the cover was replaced. This is my theory
I read that is where the tag is SUPPOSED to be. I examined the area very closely with a flashlight and from what I can tell, there is no tag there at all.
I could be wrong...
I could be wrong...
CU later. will post examination results tomorrow
