215 Pump Part Numbers???
Old Feb 3, 2005 | 04:01 PM
signature600's Avatar
What are the part numbers for the 215 pumps?
I know some of them are 897 and 913......which is better?
Would $500 be a decent deal for a used one that was "checked out" and "in spec?"
I think my old 175 is gettin' tired. I can't seem to get rid of the high speed miss. Depending on how much throttle you give it, ~2200-2500 it starts missing and white smoking. If you nail the throttle it stops white smoking, but the miss is still there.
I think I'll just try to find a 215 and be done with it. They're better anyway, right?
Thanks All,
Chris
Old Feb 3, 2005 | 04:13 PM
BoostdCTD's Avatar
I thought the 180 pump was the one that they normally go wild on with mods, rather than the 215 pump. I don't think it is just because the 215 doesn't need it as much either.
Old Feb 3, 2005 | 07:57 PM
I know, they usually use the 160 and gut it for bigger internals. But I'd like to find a 215 'cause they're cheaper than a built one, and I hear the run A LOT smoother on the street.
I'm not looking to go wild. MAYBE, down the road I'll try to get 500 hp out of her, but a good 400 with minimal smoke and low EGT's (hint, hint ) and I'll be happy...for the time being.
Chris
Old Feb 3, 2005 | 10:13 PM
Forrest Nearing's Avatar
I think you can make the numbers you're looking for with your pump, but I also think $500 for a 215 pump that's been checked out and given the OK by a pump shop is a good deal... you could turn around and sell yours for a few hundred and have enough pump for 650 hp
Forrest
Old Feb 4, 2005 | 07:41 AM
Ok, anyone got some part numbers...I know I've seen them on here before, but a can't find them using the search.
Thanks Guys,
Chris
Old Feb 4, 2005 | 08:20 AM
RedRotors's Avatar
Cummins / CPL / BOSCH
3931538 2175 0402736913
3929689 2023 0402736887
3931600 2175 0402736887
Btw, did you get my PM Chris ?
Marc/
Old Feb 4, 2005 | 08:42 AM
gunracer1's Avatar
those are the #s i look for, 887 and 913
Old Feb 4, 2005 | 12:36 PM
Marc/
Yes i did, but I can't find the boxes these injectors came out of....I put my stockers back in them
I'll look a little deeper tonight.
Chris
Old Feb 4, 2005 | 01:30 PM
RedRotors's Avatar
Chris
No problem, but if you can can anwser the other question, it will be appreciated!
Cheers,
Marc/
Old Feb 4, 2005 | 09:25 PM
OK, so I'm now sure it is a 215 pump, actually a 913...problem is that the price he quoted me was for a 175 just like mine.
Is $850 for a "Tested and Calibrated" Pump too outrageous. Could I get $3-400 for mine and cheapen it up a bit?
Thanks Again Guys,
Chris
BTW, Marc--- I'm JUST going home now, sooo I'll let you know in the morning if I found those injector boxes.
sCreamin400
Nov 2, 2008 01:46 PM
kawi600
Mar 4, 2006 07:36 AM
kawi600
Feb 17, 2006 11:03 AM
loudcummmin
Jul 10, 2005 02:25 PM
gunracer1
Dec 27, 2002 11:34 PM
