12v power options
Old Jan 15, 2010 | 05:21 PM
DixieDakDiesel's Avatar
12v power options
I have a 96 12v auto. I am running 90hp injectors, no plate, 3k gsk, 4" exhaust pinched wastegate line and a built tranny. I feel like I am making some power but not a lot I am confused and need some guidence on where to turn now.
Old Jan 15, 2010 | 06:02 PM
Tate's Avatar
Find out where your timing is, and increase it to about 16, or go higher if you are a gambling man. Turbo would be the next logical step.
Old Jan 15, 2010 | 06:34 PM
John_P's Avatar
Looks to me like you have a pretty good start with your performance upgrades. DTR Member Tate is giving you some good advice on looking at some aftermarket turbos. How many miles are on your truck?? If you have intentions of going WAY up on H.P., and or boost I would recommend looking into putting some 12mm studs in also.
John_P
Old Jan 15, 2010 | 06:52 PM
Big Deezul's Avatar
how about some tranny upgrades?
Old Jan 15, 2010 | 07:45 PM
John_P's Avatar
Big Deezul:
He said he had a built tranny in the post:
__________________________________________________ ___________
"I have a 96 12v auto. I am running 90hp injectors, no plate, 3k gsk, 4" exhaust pinched wastegate line and a BUILT TRANNY. I feel like I am making some power but not a lot I am confused and need some guidence on where to turn now. "
___________
John_P
Old Jan 16, 2010 | 02:40 PM
I currently have 127k on the truck. It is my daily driver and it has to be streetable. I currently get around 18mpg around town, then like twelve when I get on it alot. So for an extended cab long bed I'd say thats pretty good. I would like to get around 450hp out of the truck.
Old Jan 16, 2010 | 02:50 PM
Toi advance my timing I wouldn't know where to start. I mean thats a lot of work, I would most likely have someone else do it. It would be helpful if someone would do it and how much would it cost??
Old Jan 16, 2010 | 06:14 PM
John_P's Avatar
With that many miles, I would highly recommend the 12mm studs before going too radical with turbos. FWIW,.....I blew the headgasket the first time on my 1996 Dodge CTD 12 valve at 125,000 miles. At the time, I was only running an HX-40/16 Turbo putting out a little more than 40lbs. of boost and had 370 injectors to complement that turbo.
John_P
Old Jan 16, 2010 | 06:25 PM
Big Deezul's Avatar
Originally Posted by John_P
Big Deezul:
___________
John_P
missed that
Old Jan 16, 2010 | 06:34 PM
John_P's Avatar
Originally Posted by Big Deezul
missed that
No problem buddy,......I do it all the time!
Old Jan 16, 2010 | 06:45 PM
Tate's Avatar
John_P
Not to say that isn't sound advice, but I did 520hp with DDP comp injectors and a silver bullet on stock bolts and gaskets with just about 400k km on the 24v. I'm also running F1 HR370's and a 64/71 turbo on stock gasket and bolts on 250k km 12v. So the stock stuff can hang in there. Other times it will blow out like yours did. I am running conservative timing on both of those though. With the 215, it pulls back even more timing, something that won't be present on the 180 pump.
Old Jan 16, 2010 | 07:02 PM
John_P's Avatar
I don't disagree with anything you said Tate. I know there are many guys that have had real good luck running the stock headbolts and gaskets. Heck, Jeff Garmon and his Crew are a great example of that. But,.....with that being said, there are just as many that have blown the 12v head gaskets too!
I could give you a very long list, many of them right here near me.
My suggestions to DixieDak Diesel was to try and give him the best reliability from his Dodge CTD 12 valve and IMHO, that includes the addition of 12mm studs.
John_P
Old Jan 17, 2010 | 08:05 PM
Big Deezul's Avatar
it's a coin toss as to the trueness of your head to be honest
Old Jan 27, 2010 | 03:40 PM
12 valve timing
Need to know someone in the delmava area that could advance my timing. Where? How much?
robert chilton
Jun 28, 2008 08:54 AM
kawi600
15
Jan 25, 2008 11:25 PM
vernl
Nov 2, 2003 04:57 PM
Contractor
Oct 12, 2003 09:56 PM
