12v Head stud options
Old Jun 26, 2008 | 06:17 PM
robert chilton's Avatar
Is there a direct replacement headstud for the stock bolts? I want to swap out my bolts for studs but do not want to pull the head again. The head gasket doesnt have 10k on it yet. I saw where the new design ARP studs require the rocker pedastel to be milled. What other options are out there for a 12mm stud on a 12v?
Old Jun 27, 2008 | 09:05 AM
dzlfarmboy's Avatar
None really just pop your rockers off and take them to a machine shop im sure theres one close in Va Beach. Prob cost around $75. Or give Tim Barber a call He's right in Norfolk. I know he has a good local machine shop.
Old Jun 27, 2008 | 10:42 AM
Gary Emerald's Avatar
I've got a set of "torqued once" 12v ARP old style studs sitting in the closet
Old Jun 27, 2008 | 12:18 PM
rockjeep73's Avatar
If you do get a new set of ARP studs you do not have to mill down the rocker stands. You will have to clearance the valve cover but this can be done by hand with a dremel. When you install the long studs you will have to back them out about 2 turns from all the way in, so that the stud ends up flush with the nut or just slightly under when torqued.
Old Jun 27, 2008 | 12:27 PM
I'm sure it's splitting hairs, but then you end up with less thread engagement in the block
Old Jun 27, 2008 | 04:18 PM
I dont think 2 threads is that big of a deal honestly. As memory serves there was over an inch of threads to start with so I think that there is enough meat to allow for clamping force. My motor isnt really that wild but I can blow past my wastegate and hit 40lbs on my HX35. I have a S300 sitting here and I am waiting for the downpipe to come in (through Tim by the way). I just dont want to lunch the gasket again and I am playing with the thought of adding more timing after the turbo install to optimize my set up.
Can you just dremel out the valve covers with the new ARP studs? I thought that that was only with the old style studs. I have no problem with that. I just dont want to have my truck down for to long and I can play with the dremel till my hearts content. Keep the voices of experience coming.
Old Jun 27, 2008 | 05:09 PM
Well I just ordered ARP head studs so Anyone with experience with the new style and not cutting the stands please chime in.
Old Jun 27, 2008 | 08:26 PM
rockjeep73's Avatar
the only difference in the new style studs is that they are a little bit shorter to account for what they want you to mill off the rocker stand. all you need to do is dremel out the inside of the valve cover and dont run the studs all the way down until they bottom out.
Old Jun 28, 2008 | 06:41 AM
Thanks Rockjeep. Guess I will have to play with them a little after they show up. I will also run it past im when my downpipe gets here.
Old Jun 28, 2008 | 08:54 AM
97' CTD's Avatar
ARP 12MM 625's
Brandon
Onemoparnut
Mar 9, 2013 02:36 PM
ccb9955
Jun 7, 2010 08:42 AM
lostcreek21
Mar 1, 2010 06:13 PM
hic316
38
Jan 12, 2008 10:03 PM
74dart
Jul 7, 2007 07:58 PM
