12v fuel shut off
Old 01-15-2019, 04:12 PM
Brendan Finn's Avatar
12v fuel shut off
so on my 94 2500 my fuel shut off solenoid was missing a bolt mounting bolt so in got toasted when it went out so did my alternator so I replaced both my batteries now will charge but my fuel shut off solenoid won’t engage and I have to manually push the spring up to get my truck to start did I just mess up my calibration or is it a wiring problem
Old 01-15-2019, 04:21 PM
Also the old shut off worked when I manually pushed it
Old 01-16-2019, 08:07 AM
Received 2,392 Likes on 1,576 Posts
Sounds like the FSS is getting old.
Take it off and lube it up so it works smoother.
If that doesn't work it may be time for a new one.
Old 01-16-2019, 03:42 PM
texasprd's Avatar
Your FSS won't pull up when you are cranking the engine? If cleaning/lubing like Oliver suggested doesn't work, then check the wire for the pull-coil and see if there is voltage coming from the FSS relay when in crank mode. If you have voltage coming from the FSS relay in crank mode, then the pull-coil on your FSS is dead.
Old 01-16-2019, 03:43 PM
texasprd's Avatar
dkimmel
01-03-2011 10:54 PM
randyswelding
02-09-2009 10:40 PM
menzy
11-07-2008 02:07 PM
matchew
10-09-2007 07:17 PM
rodsracingteam
03-24-2007 11:04 PM
Quick Reply: 12v fuel shut off
