12v fuel filter warning
Old Oct 30, 2012 | 01:09 PM
casey sohc's Avatar
first off don't dump on me for buying an aftermarket fuel filter,last week i installed an aftermarket fuel filter from "Part source"in halifax n.s. they supply Canadian tire with parts.on my way home from our yearly camp trip i noticed the fuel gauge was dropping like a V10.i stopped at a fueling station and the entire side and underside of my truck was covered in diesel,and all under the hood was wet with diesel...the buttom of the filter where the seperator threads in was cracked and spraying fuel everywhere.EXTREME FIRE HAZARD.not to mention an enviromental issue.GKI is the brand name of the filter it was blue in color and "Made in china"on the side.check and make sure you don't have one of these on your truck.thanks JJ
Old Oct 30, 2012 | 02:54 PM
BILTIT's Avatar
Yup, that goes for all filters (oil/air/fuel). Buy good name brand filters, they are little cost for what they do and the headache they save you.
Old Oct 30, 2012 | 03:38 PM
casey sohc's Avatar
yep understood,but the mopar/cummins filter was weeping out of the seam at the top,it was made in korea,and try to find a genuine part after 5pm on a weekday when most of us work to pay for name brand equipment,my service is due early december at the dealer,i thought the filter might last more than a week before the bottom seperated from the rest of the body leaving a wonderous stream of $1.36/liter gold blowing out on the road.this was just a heads up for us all.
Old Oct 30, 2012 | 03:53 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
That's ok...We all do mistakes....I have done my share of "Duh" mistakes...
Old Oct 30, 2012 | 07:53 PM
infidel's Avatar
Beware, fuel pressure in excess of 45 psi can split open even a Fleetguard filter.
Old Oct 30, 2012 | 08:27 PM
casey sohc's Avatar
yep i knew that one,but the boss on the bottom that holds the w.i.f sensor started falling off it split about 2/3 of the way around it gave a wonderous fountain of fuel spraying straight down over the starter and front diff housing...nice!
Old Oct 31, 2012 | 01:09 AM
joem's Avatar
your filter must be drasticly different than mine, mine screwed on like a oil filter- once pre filled the truck started pefect & trouble free.
Old Oct 31, 2012 | 05:39 AM
casey sohc's Avatar
here is what my filter looks like,it's upside down in the photo.but the threads where the water seperator threads in is what cracked around the filter.
Old Oct 31, 2012 | 09:29 AM
texasprd's Avatar
"...where the water seperator threads in ..."
Not to nitpick, but just so you know in case you ever need to replace it and need to know the correct terminology - the water-separating action occurs in the filter itself. What you are referring to is the drain and water senor.
Old Oct 31, 2012 | 09:57 AM
casey sohc's Avatar
yep! the drain assembly.where it threads in where the collar meets the filter body.
Old Oct 31, 2012 | 10:41 PM
joem's Avatar
Same one indeed, look how thick that metal is- one would think that could hold common rail PSI and blow that plastic sending unit to the moon before the metal cracked
Old Nov 15, 2012 | 08:32 PM
casey sohc's Avatar
well the saga continues....yesterday on the way home the temp fuel filter (that the shop gave me to put on the truck to get me through till the "make a ruleing"on what happened to the filter that broke)did the same thing as the last one the bottom cracked.giving a nice arterial spray of diesel on the road...holy crap!so i went to the shop fully intending to place the broken filter up the rear end of the first parts clerk that looked at me the wrong way!they were great,another filter and sending off filter #2 for assessment....nice...so this morn at 8am i dropped the truck off at the local cummins dealer in dartmouth,they installed a fleetguard.they seemed very good to deal with,so i'm hoping my issues are done...has anyone heared of this or has had it happen to them???cheers JJ
jj3500
Jun 14, 2015 10:09 PM
othomas3
Oct 17, 2011 11:11 AM
Mulberryfire
Nov 4, 2010 10:52 AM
dieselfuelonly
18
Sep 23, 2010 09:27 PM
papaglock
Jul 31, 2005 03:14 AM
