changing fuel filter 12v
Old Nov 2, 2010 | 03:17 PM
Mulberryfire's Avatar
I was wondering if anyone has posted how to change the fuel filter on a 1997 12v. I have changed one on a 3rd generation before. Is it pretty much the same?? I tried searching but it came back with an error.
Old Nov 2, 2010 | 08:41 PM
STate's Avatar
I have a 98 12v and changing the fuel filter is the same as on my old 04.5 3rd gen. If your 97 has the black fuel filter housing mounted on the driver side next to the motor inside the engine compartment it should be the same.
Only difference is the lower "bowl" comes off, and the "cap" stays stationary. Just drain out all the fuel then loosen the nut on top/center to release the lower bowl portion.
And when your finished, you will need to pump the manual prime button several times (30-40 times) to get fuel back into the canister. Its located below the filter housing on the engine block. You should be able to hear it gurgle when its full. I use a broom handle to pump mine. Hope this helps.
Scott
Old Nov 2, 2010 | 09:30 PM
WUnderwood's Avatar
what Tate said, and you can also wash some of the trash out of the 'bowl' out, if there is any
Old Nov 3, 2010 | 06:28 AM
thanks guys
Old Nov 3, 2010 | 07:55 AM
patdaly's Avatar
The lower part is keyed to the upper part, ( tab and slot ) make SURE you have it engaged and you should be able to run the nut till threads are showing before placing a wrench on it.
VERY easy to get it wrong, use the wrench to pull it in, and crack the housing...........
Old Nov 3, 2010 | 12:31 PM
Dr. Evil's Avatar
I did exactly that the first time I changed mine. Make sure you take a good look at it.
Old Nov 3, 2010 | 02:30 PM
Tate's Avatar
Instead of pumping the primer, you can disconnect the shut off solenoid harness, and just crank the engine over. Once its full, reconnect the harness and fire the truck up.
Old Nov 3, 2010 | 08:09 PM
STate's Avatar
Nice! Thanks for the tip. Ill try that next time.
Scott
Old Nov 3, 2010 | 10:25 PM
D Nut's Avatar
[QUOTE=Tate;2869306]Instead of pumping the primer, you can disconnect the shut off solenoid harness, and just crank the engine over.
Please, pardon my ignorance, but where might one find this solenoid harness connection that is to be disconnected?
Old Nov 3, 2010 | 10:47 PM
Tate's Avatar
The shutoff solenoid is the cylinder that bolts to the pump by the AFC. There is a harness that comes out and has a large 3 wire plug. Thats the one you disconnect.
Old Nov 4, 2010 | 01:23 AM
Rare1's Avatar
If you pump the primer, be sure to loosen the bleed screw in the banjo bolt. I wonder if this is a good idea if you crank the engine instead? Bleed the air before it enters the injection pump.
Old Nov 4, 2010 | 09:13 AM
infidel's Avatar
Old Nov 4, 2010 | 10:52 AM
D Nut's Avatar
Thank you, kind sir's,
othomas3
Oct 17, 2011 11:11 AM
flinn101
Dec 31, 2005 06:55 PM
faurotus
14
Feb 27, 2005 11:40 AM
Slice
13
Jul 23, 2004 06:07 AM
debolton
24
Jun 29, 2004 09:22 PM
