12 valve no power
Old 01-24-2018, 11:37 AM
Kyler350's Avatar
12 valve no power
hey. Guys so I 0 cut my fuel plate and I’ve heard from lots of people that it has lots of power after you do that but mine is super gutless and I’m trying to figure out why I’ve tried playing around with my power screw and my star wheel but is it possible that if you cut the fuel plate wrong it will make it super gutless?
Old 01-24-2018, 01:41 PM
AlpineRAM's Avatar
If you mount the plate wrong .... you will have the super gutless result.
Go back there and check the position of the plate.
Old 01-26-2018, 01:23 PM
Kyler350's Avatar
How do you know if you mount the plate wrong?
Old 01-26-2018, 08:18 PM
patdaly's Avatar
First things first, was it low on power before?
What fuel pressure do you have at the pump?
Old 01-27-2018, 12:59 AM
Kyler350's Avatar
yes I was I didn’t have any rpm, right to the floor it would shift at a little over 2grand it should be shifting at 27 or 3grand,and idk what pressure my pump is putting out I don’t have pyro gauges I want them though!!!
Old 01-27-2018, 02:22 AM
AlpineRAM's Avatar
Plate too far back.
Plate turned around.
Governor arm jammed up .
There are a lot of possibilities.
But, to me your problems do not sound like plate problems.
Either your transmission is misadjusted, or you have fuel delivery problems, low boost problems, governor problems....
There is a lot going on in there that needs to be properly diagnosed before jumping in and adjusting this or that.
Get gauges first!
Prepare your transmission for the hopped up engine.
Old 01-28-2018, 02:26 PM
patdaly's Avatar
And you need a solid 25-27 PSI at idle and 32 or so at speed, otherwise your power will be low.......
Old 03-25-2018, 07:19 PM
Rare1's Avatar
How long have you had this truck? When was the fuel filter last changed? A clogged fuel filter will result in low boost and poor power.
CajunDiesel
05-23-2004 08:49 AM
piperca
33
05-11-2004 06:40 PM
skinsey
07-17-2003 05:47 PM
1320
05-17-2003 03:28 PM
phildog
04-02-2003 05:44 AM
Quick Reply: 12 valve no power
