12 valve in a 02 dodge 1500
Old Feb 10, 2014 | 07:37 AM
Greybush's Avatar
Ok I got a 02 dodge 1500 with a 12 valve dropped in it I went over it pretty good before I bought it and its pretty much done all it's really needing is ac hooked up, intercooler installed, intake heater and from my understanding these motors don't have glow plugs, so I was needing help finding a diagram as well as some actually pictures and part numbers for the intake heater and ac relays any info would be great thanks
Old Feb 14, 2014 | 09:46 AM
Greybush's Avatar
Anybody???
Old Feb 14, 2014 | 04:25 PM
CarlJensen's Avatar
Don't have photos. Grid heater can be had from salvage yard or Rock Auto. Just bolts in under air horn to manifold. Run it with a couple of Ford starter solenoids on a switch. Original is run by the computer using a temp signal from a sensor in the manifold. Things draw about 90 amps and that is why two batteries are installed. Really don't need if you are in warm country or have a block heater installed.
Old Feb 14, 2014 | 04:45 PM
CarlJensen's Avatar
Give it some time. You will get better info. I think Infidel has a wire diagram on them that is good.
Old Feb 14, 2014 | 04:47 PM
CarlJensen's Avatar
I know others have put up the diagram, do a search and see what you can find in past posts.
Old Feb 14, 2014 | 04:56 PM
patdaly's Avatar
Originally Posted by Greybush
Anybody???
I have never messed with them, but Jeff Garmon of Garmons diesel has done several, go down in the cummins conversions subforum and look for some posts by BigSwole. You might PM him or contact Garmon.
Old Feb 14, 2014 | 05:38 PM
Greybush's Avatar
Alright ill give it another search wasnt running across anything before
Old Feb 14, 2014 | 08:26 PM
CarlJensen's Avatar
Some reading for ya',,
http://dodgeram.org/tech/dsl/trouble...niford_htr.htm
Old Feb 15, 2014 | 01:01 PM
johnh's Avatar
grid heater
greybush, what is your location? i have a solenoid setup for the grid heater
Old Feb 16, 2014 | 06:41 AM
Greybush's Avatar
Thanks Carl after reading that I think I'll just do away with the system all together doesn't really sound like a very good system and if I plug it up in cold weather shouldn't have problems starting thanks for all the help guys
Old Feb 16, 2014 | 06:47 AM
Greybush's Avatar
There's more to come as I get more money coming in as I go through and make what the previous people's install look better or install more efficiently or finish what they didn't finish to retro fit the older motor to the newer truck
nintythree2wd
Cummins Conversions
Mar 5, 2009 06:15 PM
Shaders 24v
Oct 22, 2004 08:29 PM
Lockdown
Sep 11, 2004 06:13 AM
Fummins
Mar 2, 2004 04:40 PM
