P0500 & dash lighths???/
Well fellas tryin to get this rig ready for an inspection, and I have the ABS light and park break lights on. its also showing a P0500 as the only code when the key is cycled. I have looked at the park break and the shoes look to be in good shape. would it be as simple as changing out the ABS sensor on the rear diff? the two on the front bearings should be good as they were just replaced not to long ago. park break seems to ingage but with little effort the pedal can be pushed to the floor. maybe pedal is worn out, but not sure if this will cause the park light to stay on.
just put in the rear speed sensor......no change. I don't know if you have to take it for a boot to get it to clear but on we go tryin to figure this rig out. PIA.....
NoSparkplugs
17
05-17-2009 10:36 PM
